Questions on kinematics (distance/velocity/acceleration)
  • Thread starter dnt
  • Tags
    Kinematics
In summary, the conversation discusses a table showing the relationship between time and distance for a ball rolling down a hill. The first question asks for the distance after 2.2 seconds and the second question asks for the slope at 3 seconds. The conversation also delves into the concept of acceleration and the use of different points to calculate slope or velocity. It is concluded that the distance function is quadratic and that the acceleration can be found by differentiating the function. However, for a simpler solution, a tangent line can be drawn to find the slope at a specific point.
dnt
238
these should be pretty simple but for some reason i can't get them.
ok they give you a basic time vs distance table:
  • 0 sec - 0 m
  • 1 sec - 2 m
  • 2 sec - 8 m
  • 3 sec - 18 m
  • 4 sec - 32 m
  • 5 sec - 50 m
its a ball rolling down a hill which makes sense for the data. now the question is what is the distance after 2.2 seconds. can you figure that out exactly or do you just look at a graph and estimate it?
second question is what is the slope at 3 seconds? now i konw slope is change in y over change in x (meaning change in distance over change in time) which is also the velocity at 3 seconds but which two points do you use? do you use the 3 second data with the 2 second data or the 3 second data with the 4 second data? they give different answers.
third, if you do look at all the differences from one second to the next, you get a patten of how much it jumps - 2, 6, 10, 14, 18 - those are the velocities at each second, right? well since it jumps by 4 each time can i then say the acceleration is 4 m/s^2?
thanks.
s = .5at2 + v0t + s0
Plug in!
ok so i can do this:
s = .5(4)(2.2)^2 + (0)(2.2) + 0
is that correct?
am i right the a=4?
Yes, because 2=.5a -> a=4 m/s2.
  • 0 sec - 0 m
  • 1 sec - 2 m
  • 2 sec - 8 m
  • 3 sec - 18 m
  • 4 sec - 32 m
  • 5 sec - 50 m
anyone know this question?
[tex]v_{f} = v_{i} + at [/tex]
i don't think that answers my question.
the question specifically asked for slope (which in turn, is velocity) at 3 seconds. to find slope you need two points, right? well do you use 2 and 3 seconds OR 3 and 4 seconds to find the slope at that point?
You are asked, apparently, for an "instantaneous" speed and you don't have enough information to do that. To find instantaneous speed (unless the distance-time graph is a line and speed is constant), you would have to know the distance-time function and you only have it at specific times. What you can do is anyone of what you are suggesting- use the distances at 3 and 4 seconds to get the "average speed between t=3 and t= 4", (32-18)/1= 14 m/s, use the distances at 2 and 3 seconds to get the "average speed between t= 2 and t= 3,(18-8)/1= 10 m/s, or even average those two answers- (10+ 14)/2= 12. For this particular problem, that turns out to be the same as if you find the "average speed between t= 2 and t= 4", symmetric about t= 3, (38- 8)/2= 24/2= 12 m/s. If you want to do a lot of work to get a very accurate answer, you might find a polynomial function that fits all of the points and differentiate that! Actually, here, it is not a "lot of work". It look pretty obvious that each distance, in m, is equal to twice the time, in s, squared: d= 2t2.
The instantaneous speed, at t= 3, is the derivative of that, 4t, evaluated at t= 3: 4(3)= 12 m/s.
Of course, that was to be expected. Something moving under gravity has a constant acceleration and so its distance function is a quadratic. That was what apmcavoy was telling you in the first reply to your post.
ah. thanks!
Solving the slope
I don't think that you need to take the derivative especially if you are not in a calculus based physics course.
To find the slope at one point draw a tangent line. I promise there is an explantion of how to do this in your book. It should just touch the curve. The tangent line is straight so take any 2 points and find the slope.
1. What is the definition of kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion.
2. How is distance different from displacement in kinematics?
Distance is the total length of the path traveled by an object, while displacement is the shortest distance between the initial and final positions of the object.
3. What is the difference between speed and velocity?
Speed is the rate of change of distance, while velocity is the rate of change of displacement. Speed does not take into account the direction of motion, while velocity does.
4. How is acceleration calculated in kinematics?
Acceleration is calculated as the rate of change of velocity. The formula for acceleration is a = (vf - vi) / t, where vf is the final velocity, vi is the initial velocity, and t is the time taken.
5. What is the difference between average and instantaneous velocity?
Average velocity is the total displacement divided by the total time taken, while instantaneous velocity is the velocity at a specific moment in time. Average velocity can be calculated over a longer period of time, while instantaneous velocity is calculated at a specific instant.
