What Causes Changes in the Wavelength and Velocity of Light During Refraction?
In summary, when light falls from a medium of lower optical density to one of higher optical density, the direction of the light does not change, but the speed does change due to the change in medium. However, the frequency remains constant to maintain continuity across the boundary. This is because frequency is source dependent. Velocity changes as it moves into a medium with a different refractive index, which then changes the wavelength.
Misr
385
1-when a light ray falls on a piece of glass,it refracts. which of the following concepts doesn't change : speed-frequency-wavelength
indeed speed does change because of changing the medium but frequency doesn't .
what causes wave length to change?change in speed?(V=freq*wavelength)
right?do u have a better explanation?
2-when light falls from a medium of lower optical density to that of higher optical density with an angle of incidence=zero ,of course direction doesn't change but what about speed??speed changes as a result of changing the medium.right?
Science news on Phys.org
hello there?
Hi. Sorry, not all threads are quickly responded to. I don't know the answers to your questions myself, and the people that do might not be online. Just be patient.
When a wave moves from one medium into another with different refractive index, it is the velocity and wavelength that change, while the frequency remains constant.
The frequency must be invariant to satisfy the condition that the fields are continuous across the boundary at all times.
Claude.
Claude.
Claude is correct. Frequency will always remain constant, as frequency is source dependent. Velocity changes as it moves into a medium with a different refractive index, which then changes the wavelength. Obviously, if v increases λ increases proportionally and vice versa.
1. What is light refraction?
Light refraction is the bending of light as it passes through different mediums, such as air, water, or glass. This bending occurs due to a change in the speed of light as it travels from one medium to another.
2. How does light refraction affect the appearance of objects?
Light refraction can cause objects to appear distorted or shifted, depending on the angle and density of the medium it is passing through. This is why objects may appear differently when viewed through water or a magnifying glass.
3. What is the cause of light refraction?
The change in speed of light as it passes through different mediums causes light refraction. This change in speed is due to the change in the density of the medium, which alters the path of the light rays.
4. What is the law of refraction?
The law of refraction, also known as Snell's law, states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the speeds of light in the two mediums. In simpler terms, this means that the angle at which light bends is determined by the difference in the densities of the two mediums.
5. How is light refraction used in everyday life?
Light refraction has many practical applications, such as in the design of eyeglasses and lenses, which use the bending of light to correct vision. It is also used in cameras and telescopes to focus and magnify images. Additionally, light refraction is essential in the study of meteorology and oceanography, as it affects the behavior of light in the atmosphere and water.
10K
