johnmartin
- 5
The current state of NASA’s version of cosmology is amazing to watch –
What is the cause of galaxy redshift? According to NASA, redshift is caused by the motion of the galaxy away from the observer or the expansion of spacetime itself.
According to modern cosmology, which NASA endorses, the Milky Way is moving through space at 600km/s and the Earth is moving through space at 30km/s and the sun is moving through space at 250km/s. So if we total up these velocities we have 880km/s for the velocity of the Earth through space, relative to the CBR. Conservatively according to NASA, the earth’s motion through space is 600km/s.The Sun orbits the center of the Milky Way at about 250 km/second and it takes about 220 million years to complete an orbit.
The Milky Way is part of a group of galaxies known as the Local Group. All of these are moving relative to each other due to their gravitational interaction with speeds of around 100 km/s or less. Calculating the velocities of the galaxies in the Local Group is difficult because there are probably members that have not yet been discovered because they are too dim or are obscured by the plane of the Milky Way. The radial velocities relative to the Milky Way are found by measuring Doppler shifts in the spectra of stars in the galaxies. You will find more information at http://imagine.gsfc.nasa.gov/docs/ask_astro/answers/970821a.html
The Local Group is also moving at about 600 km/second relative to the cosmic microwave background. There's a nice picture of this at http://antwrp.gsfc.nasa.gov/apod/ap960205.html
cosmological redshift
An effect where light emitted from a distant source appears redshifted because of the expansion of spacetime itself. Compare Doppler effect.
Doppler effect (C.J. Doppler)
The apparent change in wavelength of sound or light caused by the motion of the source, observer or both. Waves emitted by a moving object as received by an observer will be blueshifted (compressed) if approaching, redshifted (elongated) if receding. It occurs both in sound and light. How much the frequency changes depends on how fast the object is moving toward or away from the receiver. Compare cosmological redshift.
- If the redshift of galaxies means the universe is expanding is the correct interpretation of redshift, then the following questions apply -
- If the universe is expanding in all directions, then are the distances between the galaxies observed to be getting larger over the years? If so, what is the evidence?
- If the universe is expanding in all directions and the galaxies are moving away from Earth at large velocities, are the galaxies observed to have light dimmed over the years? If so, where is the evidence? If not, how does science explain the large velocities without the need for galaxy light dimming as seen from the earth?
- According to modern cosmological theory as stated by NASA, the galaxies are moving away from the Earth due to the universe’s expansion and along with this, the space time continuum is also expanding between the galaxies and the earth. As spacetime is merely a version of Cartesian coordinates, (x,y,z,t), which is merely a mathematical model, how then does light redshift, when a mathematical model of (x,y,z,t) is said to expand?
- In another way, x,y,z,t is not a physical thing or physical cause or physical anything at all, so how can x,y,z,t exist in the real, let alone expand in the real and then be a cause of redshift in the real?
- As spacetime is said to expand between the galaxies and the earth, because of the big bang, when then is the cause of the expansion of x,y,z,t? What experimental evidence is there that x,y,z,t exists and can even expand?
- What experimental evidence is there that an expanding x,y,z,t acts on light to make light redshift?
- If x,y,z,t expands, that means it has a change in distance over time, meaning an expanding x,y,z,t has a velocity and possibly an acceleration as well. As such, how is the velocity of expansion calculated?
- What is the x,y,z,t expansion referred to as the zero velocity benchmark? Is it space, which is to be self referencing? Or is it the earth?
- If the x,y,z,t expansion is referred to the Earth as the zero velocity benchmark, doesn’t this mean the theory is merely an Earth based theory, which assumes the Earth is stationary relative to the moving galaxies and expanding spacetime? Explain.
- If x,y,z,t is expanding, does relativity also apply the Lorentz contraction to this expansion? If so, what then is the proper distance used and how do relativists know experimentally?
- If x,y,z,t is expanding spacetime, how is this applicable to Hubble’s law that does not use spacetime in its model, but derived his law from empirical observation?
- If a proper distance is used in Hubble’s law, doesn’t that mean the distance is relative to a motionless observer at the Earth and therefore Hubble’s law is then evidence for a stationary earth?
- If Hubble’s law uses proper distance, but the Earth is not stationary, what then is the proper distance relative to?
- If Hubble’s law uses proper distance relative to the CBR then, are the velocities of say 600km/s, 100km/s and 30km/s used in the calcs to remove the Earth's various velocities to then determine the proper distance relative to a stationary earth?
- Assuming the Hubble constant of 65km/s per Mpc is correct, are the velocities of say 600km/s, 100km/s and 30km/s used in the calcs to remove the Earth's various velocities to then determine the proper distance relative to a stationary earth? If so, how is it that there have been studies that show galaxies are uniformly quantized around the earth, even though the Earth is supposedly moving through space at such a large velocity?
Put in another way, if the Earth is moving through space at say 600km/s, then this velocity must be accounted for in the redshift calculations. As such, the earth’s velocity of 600km/s must be removed from galaxies to which the Earth is moving towards, not removed from galaxies which it moving against and added to galaxies it is moving away from. Then the uniform distribution of galaxies around the Earth is a simply fantastic fluke of nature, meaning, if the 600km/s is correctly used in the redshift calcs to really have the redshift as a Doppler shift, then the galaxies in front of the Earth's motion are moving along with the Earth and the galaxies behind the earth’s motion at the same velocity.
If the galaxies in front and to the rear of the Earth's 600km/s motion, move along with the earth, then -
Galaxy in front of earth’s motion is 12km/s + 600km/s = 612km/s relative to 600km/s earth.
Galaxy at the rear of the earth’s motion is 12km/s – 600km/s = 582km/s relative to 600km/s earth.
This of course means galaxies in front of and behind the earth’s motion are some how attached to the Earth's motion. What an amazing phenomena the big bang theory produces when its concepts are consistently applied! Yet again, what a huge problem for the big bang theory when the concepts are consistently applied! The problem probably hasn’t even been noticed, let alone discussed and dismissed by relativists.
- What is the physical cause of the spacetime expansion, which is really only an expansion of the quantities x,y,z,t?
- As the universe is expanding in all directions, what is the physical cause of expansion of spacetime between the galaxies?
- Let us assume the bending of spacetime around matter is the cause of gravity as relativity says it is. If then science posits the physical cause of expanding spacetime continuum is dark matter and dark energy, and matter is said to have a bending of space time around it, then how does more matter in the universe cause space time to expand? After all, if more matter exists, then shouldn’t that mean that spacetime curves more, causing the universe to contract, rather than expand.
- Alternatively, if more dark matter causes to flatten and therefore expand, how can a flattening of the spacetime cause the universe to expand, when almost all the universe already has a flat spacetime curvature?
- If dark energy causes the expansion of spacetime, what are the properties of this dark energy which can expand merely a mathematical concept?
- If dark energy causes the expansion of spacetime, what are the properties of this dark energy which cause spacetime to expand? Does the dark energy heat up the spacetime and cause it to expand like a hot iron rod? Or does it somehow bend of flatten spacetime?
- If dark energy affects space-time curvature, what is the experimental relationship between dark energy and change in space-time curvature? How do we know experimentally or mathematically?
- If there is expansion of space-time between galaxies that are closer and further away from the earth, what has been observed in regard to the light that travels from further galaxies, through the expanding space-time continuum of closer galaxies. Shouldn’t the light traveling between the closer galaxies actually make the light expand?
- Does the cause of expansion of spacetime between galaxies act at a constant rate, or at a different rate? Evidence?
- When redshifts are observed, how are the velocities of the galaxies calculated? Do the velocities incorporate the velocity of the Earth at 600km/s though space? If so, please show the calcs.
- If the redshift observations are considered to be observations of real velocities, then doesn’t that mean if say a redshift which produces a velocity of say 12km/s or 72km/s, really means the galaxy is moving 612km/s and 672km/s, because the observations are being made from earth, which is traveling through space at 600km/s?
- If the earth’s velocity is taken into account when making the redshift observation, doesn’t this place into question Hubble’s law of distance, whereby redshift is proportionate to distance, simply because the Hubble’s law is related to a mythical non moving point in the universe?
- The Hubble telescope is used to take pictures of the universe. The satellite travels in an orbit with a velocity of 17,500 mph. The lenses used are shaped according to a very accurate design. If the lens is out on only a fraction of a mm, then the telescope will not be able to take good quality pictures.
Hubble's mirrors are very smooth and have precisely shaped reflecting surfaces. They were ground (shaped by removing glass with abrasives) so that their surfaces do not deviate from a perfect curve by more than 1/800,000ths of an inch. If Hubble's primary mirror were scaled up to the diameter of the Earth, the biggest bump would be only six inches tall. http://hubblesite.org/the_telescope/nuts_.and._bolts/optics/ - When we inspect some of the literature on the lens design here - http://www.pgccphy.net/ref/hst-optics.pdf, there is no discussion whatsoever on the Lorentz contraction used in the design. The reason of course is the lens doesn’t need the Lorentz contraction and the Ritchey–Chrétien telescope criteria used in the telescope does not require the use of relativity theory - http://en.wikipedia.org/wiki/Ritchey–Chrétien_telescope#Mirror_parameters. Evidently the Hubble telescope lens design overturns relativity theory. This is not unexpected as the Lorentz contraction is merely science hodgepodgery, which is routinely ignored by NASA herself when building her satellites.
- If the earth’s velocity is not taken into account when making the redshift observation, doesn’t this place into question Hubble’s law of distance, whereby redshift is proportionate to distance, simply because the law is not observationally related to a stationary object?
- Quasars with greater redshifts have been found in front of galaxies with lesser redshifts. How is this observed phenomena accounted for in modern cosmology according to redshift indicating distance? It seems redshift does not indicate distance as observed, but does indicate distance according to Hubble’s law. How is this contradiction resolved?
- If the Earth orbits the sun in an ellipse, this means over a year, the Earth moves closer and further away from the sun. Has the sun been observed to become redshifted and blueshifted due to the Earth's motion away and towards the sun?
- If the sun is moving through space at 600km/s, does light from the sun aberrate?
- If black holes exist, then they suck in all matter around them, including light. Does a black hole then suck in dark matter and dark energy and if so, doesn’t that mean if black holes exist, then the amount of dark matter and dark energy should decrease over time, causing the universe to contract, rather than expand?
- If black holes exist, then they suck in all matter around them, including light. If the universe is then expanding, which is caused by dark matter and dark energy, then this dark matter and dark energy must have been much greater than it was billions of years ago and the universe must have expanded at far greater velocities than it currently does. However modern science says the universe is expanding at greater velocities, meaning dark matter and energy must be increasing. How does modern science explain the loss and gain of dark matter and energy to account for black holes in an expanding universe?
- If there is some other explanation for the existence of black holes and the expanding universe through dark matter and dark energy, what is the science explanation?
- If the universe is expanding in all directions and this expansion is caused by a massive force that permeates the entire universe, what is the cause of this force that can expand spacetime, but doesn’t prohibit the curving of spacetime around collapsing stars? It seems this mysterious force can cause a massive expansion when needed, but cannot counteract a relatively small contraction of matter when it is observed. Please comment on the apparently contradictory properties of this mysterious cause acting throughout the universe.
- If black holes exist, then they suck in all matter around them, including light, how then do black holes not expand, when they are surrounded by dark matter and dark energy that causes expansion?
- If black holes exist, why do they remain stable in size and not expand along at the same rate as the surrounding galaxy movement and cosmological expansion rate, with dark matter and dark energy?
The final and most important question – - As x,y,z,t is merely a mathematical concept and not related to anything physical in the real, why then do so many scientists take cosmological redshift to mean the expansion of a quantity as a real expansion of a distance between galaxies and the earth?
