Quick DE fix
  1. Apr 22, 2010 #1
    I'm looking to solve a DE for a problem I have but I haven't done so in a while and must be forgetting something. I've checked the answer in Mathematica and what I'm getting is wrong.
    u''(r)+1/r u'=G/m
    3. The attempt at a solution
    homogeneous solution:
    a^2+1/r a = 0 -> a = 0, -1/r
    u1 = Ae^(-1)+B
    try u2 = c r (as a constant B already exists as part of the solution, multiply by r)
    u' = c u'' = 0
    c/r = G/m
    c = Gr/m
    u2 = Gr^2/m
    u = Ae^(-1)+B+Gr^2/m
    Whereas the actual solution is
    u = A Ln(r)+B+Gr^2/4m
    Thanks for any help
  3. Apr 22, 2010 #2
    Staff: Mentor
    You are tacitly assuming that r is a constant, but it's not. It's the independent variable.
    Your DE is u''(r) + (1/r)u'(r) = G/m
    Since there's no u(r) term, I would make this substitution.
    Let w(r) = u'(r) ==> w'(r) = u''(r)
    With this substitution you can rewrite the DE as
    w'(r) + (1/r)w(r) = G/m
    Now you can use the standard technique of finding an integrating factor, v(r) = e^{integral(1/r).
    That's what I would do.
  4. Apr 22, 2010 #3
    Thanks, that worked out good.
    Could you point out in my initial work where I implied r was constant? because I didn't mean to.
  5. Apr 22, 2010 #4
    Staff: Mentor
    You treated the equation u'' + (1/r)u' = G/m as if it were a constant coefficient differential equation.
    From the homogeneous equation, u'' + (1/r)u' = 0, you got a characteristic equation of a^2 + (1/r)a = 0, and then factored the left side. This would have worked if r were a constant, but r is the independent variable, or so I gather by your use of u''(r).
    It's the difference between, say y' + 2y = 0 (with general solution y = Ae-2x) and y' + xy = 0 (with general solution y = Ce-(1/2)x2).
  6. Apr 22, 2010 #5
    Cheers, I understand now
