• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Quick Momentum Problem
  • Thread starter lubuntu
1. Homework Statement
Two objects have the same momentum, object 1 is heavier than object 2. You bring each to a stop by applying a force of equal magnatude in each case. How does the time to stop each object compare and the distance.
2. Homework Equations
mv=p f=ma etc.
3. The Attempt at a Solution
I think the the time and distance are equal in both cases because if you solve each quantity for a and v in each case you get an equation where you divide the mass by sum number and set it equal to zero, so the mass cancels out. Just looking to confirm.
Pengwuino
You can also think of it in the following way with a constant force:
[tex]
F = \frac{{dp}}{{dt}}
[/tex] thus equal forces will result in equal momenta changes over the same period of time in this case.
Doc Al
Mentor
44,766
1,044
What does distance and force relate to? Is that the same for different masses that happen to have the same momentum?
Related Threads for: Quick Momentum Problem
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
