Homework Help: Quick question about logarithims
  1. May 12, 2010 #1
    I solved for the equation
    [tex] \frac{f}{2} ln\frac{Tf}{Ti} = - ln \frac{vf}{vi} [/tex]
    I know to simplify the equation I need to Exponentiate both sides
    [tex]
    e^{\frac{f}{2}} * e^{ln\frac{Tf}{Ti}} = e^{ln\frac{vi}{vf}} [/tex]
    note i changed [tex] - ln \frac{vf}{vi} \textrm{ too } ln\frac{vi}{vf} [/tex] and removed the negative sign
    after exponentiating both sides I get
    [tex] e^{\frac{f}{2}} * \frac{Tf}{Ti} = \frac{Vi}{Vf} [/tex]
    But I'm not sure if I put the f/2 in the right place
    My equation should be reading
    [tex] {\frac{Tf}{Ti}}^\frac{f}{2} [/tex]
    but I don't know how to get to that
    from exponentiating [tex] \frac{f}{2} \frac{Tf}{Ti} [/tex]
    could someone please expain the rules behind this?
    original question:
    solve an equation for the work done in adiabatic compression
    [tex] U = \frac{f}{2} N \kappa T [/tex]
    [tex] dU = \frac{f}{2} N \kappa dT [/tex]
    the work done during quasistatic compression is -P dv
    [tex] \frac{f}{2} N\kappa dT = -P dV [/tex]
    using the ideal gas law to write P the pressure in terms of the variables T and v
    ideal gas law: [tex] \frac{N \kappa T}{V} = P [/tex]
    i get
    [tex] \frac{f}{2} N\kappa dT = -\frac{N\kappa T}{V} dv [/tex]
    simplifying by canceling out N K gives
    [tex] \frac{f}{2} dT = -\frac{T}{V}dv [/tex]
    separation of variables because this is a differential equation
    [tex]
    \frac{f}{2} \frac{dT}{T} = -\frac{dV}{V} [/tex]
    integrating both sides with respect to initial and final volume/temperatures
    I get the equation
    [tex] \frac{f}{2} \int_{Ti}^{Tf} \frac{1}{T}dT = -\int_{Vi}^{Vf} \frac{1}{V}dV [/tex]
    integrating
    [tex] \left \frac{f}{2} lnT \right|_{Ti}^{Tf}= \left -lnV\right|_{Vi}^{Vf} [/tex]
    evaluating
    [tex] \frac{f}{2} lnTf - lnTi = -lnVf + lnVi [/tex]
    noting that lnx - lny is equivalent to ln(x/y)
    simplifying to get
    [tex] \frac{f}{2} ln\frac{Tf}{Ti} = ln\frac{Vi}{Vf} [/tex]
    this is where I was having the exponential problem
    do i raise e to the whole of the left side? or the individual parts?
    [tex] e^\frac{f}{2} e^{ln\frac{Tf}{Ti}} \textrm{ or do i } e^{\frac{f}{2} ln{Tf}{Ti} [/tex]
    what happens to the f/2?
    I know each of Tf and Ti should be raised to the power of f/2 afterwards
    but I do not understand how that works
  3. May 12, 2010 #2
    Quick info about exponentials:
    [tex]x^ax^b = x^{(a+b)}[/tex]
    [tex]\frac{x^a}{x^b} = x^{(a-b)} [/tex]
    [tex](x^a)^b = x^{ab} [/tex]
    So, when you exponentiate
    You get
    [tex]e^{\frac{f}{2} ln\frac{T_f}{T_i}} = e^{ln\frac{V_i}{V_f}} [/tex]
    But remember that
    [tex]\frac{f}{2} ln\frac{T_f}{T_i} = ln(\frac{T_f}{T_i})^{(\frac{f}{2})}[/tex]
    Plug-in that on your equation to get
    [tex](\frac{T_f}{T_i})^{(\frac{f}{2})} = \frac{V_i}{V_f} [/tex]
    Was that what you wanted?
    ________________________
    EDIT:
    Instead, if you had done
    [tex]e^{\frac{f}{2}}e^{ln\frac{T_f}{T_i}} = e^{ln\frac{V_i}{V_f}} [/tex]
    On the left-hand side, you would be implying that
    [tex]e^{\frac{f}{2}}e^{ln\frac{T_f}{T_i}} = e^{(\frac{f}{2}+ln\frac{T_f}{T_i})} [/tex]
    Which is incorrect, as you can clearly see, because the original expression was
    [tex]\frac{f}{2}ln\frac{T_f}{T_i}[/tex]
    And not
    [tex]\frac{f}{2}+ln\frac{T_f}{T_i}[/tex]
    So a quick explanation to your question would be reviewing the first exponential property that I've posted above, that is, the product one.
