Quick question about numerators
I have a formula
Ho / Hi = -So / Si
The question is if I have this:
0.5/Hi = 2.0/8.0
how do I move the 0.5 numerator to the other side of the equation? What is the algebraic property that describes this? I realize this is a simple question but isn't it always the simple ones that get you?
Multiply both numerators by 2. This gives you
1.0/Hi = 4.0/8.0
That should do it.
I don't see how that solves the problem.. I need remove the fraction on the left side and keep only Hi. Maybe I am approaching this wrong, if so could someone explain why? I know that 1/Hi is the same as H^-1.
I think this belongs in homework help. I will post it there.
HallsofIvy
821
I have a formula
Ho / Hi = -So / Si
0.5/Hi = 2.0/8.0
Then you should have said that to begin with and not just "move the 0.5 numerator to the other side of the equation". In fact, it isn't the numerator that is the problem. To get rid of the fractions multiply both sides of the equations by the denominators:
[tex]\frac{0.5}{H_i}(8.0H_i)= \frac{2.0}{8.0}(8.0H_i)[/tex]
On the left the "Hi" terms cancel and on the right the "8.0" terms cancel:
(0.5)(8.0)= 2.0Hi or 4.0= 2.0Hi.
Mentallic
3,796
94
Use these basic rules of fractions:
Given any numbers (denominator [tex]\neq[/tex] 0) ~ [tex]\frac{a}{b} * \frac{x}{y} = \frac{ax}{by}[/tex]
If there are common factors in both the numerator and denominator, you can cancel them out ~
[tex]\frac{a}{b} * \frac{x}{a} = \frac{ax}{ba} = \frac{x}{b}[/tex]
So, [tex]\frac{H_o}{H_1}=\frac{-S_o}{S_1}[/tex]
If you try to make H1 the subject of the equation, it needs to come out of the denominator.
So, to cancel it from the denominator, multiply both sides by H1
[tex]\frac{H_o}{H_1}*\frac{H_1}{1}=\frac{-S_o}{S_1}*\frac{H_1}{1}[/tex]
Simplifying:
[tex]\frac{H_o}{1}=\frac{-S_o * H_1}{S_1}[/tex]
Now that H1 is in the numerator, simply divide/multiply both sides of the equation by the required variable so as to cancel out those variables on the same side as H1:
Multiplying by S1 and dividing by -So
[tex]\frac{H_o}{1}*\frac{S_1}{-S_o}=\frac{-S_o * H_1}{S_1}*\frac{S_1}{-S_o}[/tex]
Simplifying by cancelling common factors in numerator and denominator:
[tex]\frac{H_o*S_1}{-S_o}=H_1[/tex]
Want to reply to this thread?
"Quick question about numerators" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
