Earth's Elliptical Path: Acceleration Direction Explained
  • Thread starter alexmahone
  • Tags
    Ellipse
In summary, the Earth travels in an elliptical path with the sun at one of its foci. Using the parametrizations for the Earth's path and differentiating twice, it can be concluded that the Earth's acceleration is directed towards the center of the ellipse. However, the force on the Earth is due to the sun, which may lead one to believe that the acceleration should be directed towards the sun instead. This raises the question of where the acceleration of a particle would be directed if its coordinates were given by a similar parametrization.
alexmahone
304
The Earth travels in an elliptical path with the sun at one of its foci. Is the acceleration of the Earth directed towards the sun or towards the centre of the ellipse?
The Earth's elliptical path can be parametrized as:
[itex]x=acos (pt)[/itex]
[itex]y=bsin (pt)[/itex]
Using the above parametrizations and differentiating twice, I get that the Earth's acceleration is directed towards the centre of the ellipse.
However the force on the Earth is due to the sun, and so I feel the Earth's acceleration must be directed towards the sun.
Please help.
That's correct.
EDIT: you're paramaterization is incorrect if "t" is really the time. It implies the speed is the same at aphelion and perihelion, but in reality it is faster at perihelion.
Redbelly98 said:
That's correct.
Thanks, Redbelly98! :)
Forget the Earth - sun example.
What if the x and y coordinates of a particle were given by the parametrization where t is time? Where would the acceleration of the particle be directed towards?
That's a reasonable question. Well, you can take the 2nd derivative of both x and y with respect to t, and see what direction the vector
a = (d2x/dt2, d2y/dt2)
points in.
1. What is an ellipse?
An ellipse is a geometric shape that is defined as a closed curve that is shaped like a flattened circle. It has two focal points, and the distance from any point on the ellipse to the two focal points is always the same.
2. How is an ellipse different from a circle?
An ellipse is different from a circle in that it has two focal points instead of one, and the distance from any point on the ellipse to the two focal points is always the same. In a circle, the distance from any point on the circle to its center is always the same.
3. What is the equation for an ellipse?
The equation for an ellipse is (x-h)^2/a^2 + (y-k)^2/b^2 = 1, where (h,k) is the center of the ellipse and a and b are the lengths of the semi-major and semi-minor axes, respectively.
4. How is an ellipse used in science?
Ellipses are used in science to describe the orbits of planets and other celestial bodies around a central point (such as the sun). They are also used in optics to describe the path of light through lenses and mirrors.
5. Can an ellipse have negative values?
Yes, an ellipse can have negative values. The equation for an ellipse allows for negative values, and the shape can be reflected across the x-axis or y-axis to create an ellipse with negative values.
