Quick question on force
Here is the problem:
Calculate the force exerted on a rocket, given that the propelling gases are expelled at a rate of 1500kg/s with a speed of 4*10^4 m/s (at the moment of take off)
I know that force is equal to the mass times the change in velocity over the change in time. Can I use a one second interval for the time and just make up a time like that?
Answers and Replies
Yes, you are on the right track. The gas exerts the same force on the rocket as the rocket exerts on the gas. Find the acceleration of the gas by setting time equal to one second, and displacement equal to [itex]4\times10^{4}[/itex] meters. Then use [itex]F_{net}=ma[/itex].
Solving for acceleration won't the acceleration be the same as the velocity in this equation?? I used the formula of Vf=Vo+at
Andrew Mason
7,671
393
Use:
[tex]\vec F = \frac{\delta \vec p}{\delta t}[/tex]
In this case:
[tex]\frac{\delta p}{\delta t} = v \frac{\delta m}{\delta t}[/tex]
Where [itex]\frac{\delta m}{\delta t} = 1500 kg/sec[/tex]
AM
Thankyou very much!!!
Oh boy...forget this post. Not sure what I was thinking here... :eek:
Related Threads on Quick question on force
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
