1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Quick question w = ma
  1. May 13, 2007 #1
    I have to find the mass of something.... the weight is 358170 lbs
    2. Relevant equations
    w = ma
    a = 9.8m/s2
    3. The attempt at a solution
    do i convert lbs into kilograms?
  3. May 13, 2007 #2
    Hootenanny
    Staff Emeritus
    Edit: Correction, you should convert lbs (force) into newtons.
  4. May 13, 2007 #3
    so then what would the unit for the mass be
  5. May 13, 2007 #4
    Hootenanny
    Staff Emeritus
    See the correction in my previous post.
  6. May 13, 2007 #5
    thank you very much
  7. May 13, 2007 #6
    Now that i have mass, I need to find the debroglie wavelength...
    so i did wavelength = h/mv
    what unit is used for the debroglie wavelength
    i have J-s/(Kg)*(km/h)
    it should be a distance i believe, so would it be kilometers?
  8. May 13, 2007 #7
    Hootenanny
    Staff Emeritus
    You need to convert your speed to km/s, then your distance will be in km. However, it is generally best to work in SI units throughout, i.e. m,s, kg etc.
    In general the de Broglie wavelength is usually expressed in nm.
  9. May 13, 2007 #8
    why dont you stick to SI units for a while..that would allow easy substitution of h .
    Convert velocity to m/s
  10. May 13, 2007 #9
  11. May 13, 2007 #10
    Hootenanny
    Staff Emeritus
    You may want to check your conversion from pounds-force to newtons to kilograms.
  12. May 13, 2007 #11
    I used google and it gave me:
    (4 293 203.81 N) / (9.8 (m / (s^2))) = 438 082.021 kilograms
  13. May 13, 2007 #12
    Hootenanny
    Staff Emeritus
    Note that pounds-force is not the same as pounds. You need to convert 358170 pounds-force into newtons, then convert this into kg.
  14. May 13, 2007 #13
    358170/9.8 = 36547.959N
    = 3 726.854 623 472 kilograms
  15. May 13, 2007 #14
    Hootenanny
    Staff Emeritus
    Again, this is not correct. Type into google "convert pounds force to newtons";
    358170 [pounds-force] = 358170 x 4.44822162 [newtons]
  16. May 13, 2007 #15
    358 170 pounds force = 1 593 219.54 newtons
  17. May 13, 2007 #16
    Hootenanny
    Staff Emeritus
    Correct. Now convert that into kg
  18. May 13, 2007 #17
    to Kg = 162573.4224
  19. May 13, 2007 #18
    Hootenanny
    Staff Emeritus
    Beware of rounding errors. I get 162407.7
  20. May 13, 2007 #19
    1 593 219.54 / 9.8 = 162 573.422
    using google i got this answer
  21. May 13, 2007 #20
    Hootenanny
    Staff Emeritus
    Apologies, I was using g = 9.81, your correct. :approve:
Have something to add?
Similar Discussions: Quick question w = ma
  1. MA Question (Replies: 6)
  2. Force=MA question (Replies: 7)
Loading...
