Quick sequence questions
  1. Nov 15, 2008 #1
    I know that the statements: if lim sup|s_n|=5, then s_n is bounded, and if lim sup s_n = 0 then lim sup |s_n| are false but I can't think of counter examples? Can someone suggest one or two please. many thanks
    2. consider the sequence s_n convergent. Define a new sequence t_n such that
    t_n = s_n + (-1)^(n)*(s_n)
    a. show that t_n diverges
    well lim sup s_n = s
    then t_n = s_n*(1 + (-1)^n)
    and finally
    1/s * lim sup t_n = lim (1+(-1)^n)
    the last sequence diverges because no matter how big n gets
    the set will be {0, 2/s, 0, 2/s, 0, 2/s} at some point.
    b) show by any method that t_n has a convergent subsequence
    if we look at the previous tail we see that the 2k terms of n give a convergent subsequence that is
    {0,0,0,0..}
    right?
    thansk!
  3. Nov 16, 2008 #2
    HallsofIvy
    Then you know wrong. If lim sup |s_n|= 5, then no subsequence can converge to anything larger than 5 or less than -5. That means that only a finite number of its terms can be larger than 5 or less than 5 and so the sequence is bounded by the largest of those and the smallest. If lim sup |s_n| is any finite number then the sequence s_n is bounded. I don't know what you mean by the second. "If lim sup s_n= 0 then lim sup |s_n|" is WHAT? Yes, it is false that the lim sup |s_n|= 0. s_n= 1/n if n is even, -1 if n is odd is a counter example.
    Are you assuming that s is not 0? you are not told that.
    No, it won't. It will "at some point" become a sequence in which odd terms are 0 and even terms converge to 2/s but not equal to what you have. And in any case, dirvergence of that sequence is not what you wanted to prove! Simpler is just to note that t_n itself is 0 for n odd, s_n for n even. In fact, the "theorem" as stated is not true. If s_n converges to 0, then t_n also converges to 0. You need the additional requirement that s_n NOT converge to 0 in order to argue that the sub-sequence {t_{2n}) converges to 2s while {t_{2n+1}) converges to 0. If 2s and 0 are different, {t_n} does not converge.
    [/quote]
    NO!!! t_n= s_n+ (-1)^n s_n is 0 for n odd: 2k+1, not 2k!
  4. Nov 16, 2008 #3
    it sounds like you know this material very well. The instructions for problem 2 include the important fact that s_n be a convergent sequence with a limit not equal to 0. Also, thank you for pointing out the fact that t_n = 0 on odd terms.
    I don't understand your example for s_n = 1/n on even and -1 on odd?
    Xould you be more specific
    the terms are {-1, 1/2, -1, 1/4, -1, ...}
    lim sup s_n = 0?
