Homework Help: Quick Tension problem
  1. Apr 17, 2006 #1
    I've been working on this problem and I got every part right except part F which asks for tension.
    A sinusoidal wave is traveling on a string with speed 110 cm/s. The displacement of the particles of the string at x = 23 cm is found to vary with time according to the equation
    y = (4.9 cm) sin[1.5 - (7.2 s-1)t].
    The linear density of the string is 2.2 g/cm. What are (a) the frequency and (b) the wavelength of the wave? If the wave equation is of the form
    y(x,t) = ym sin(kx - (omega)t),
    what are (c)ym, (d)k, and (e)Omega? (f) What is the tension in the string?
    a)f=1.15 Hz
    b)wavelength = 95.7cm
    c)Ym=4.9cm
    d)k=6.52 rad/m
    e)omega=7.2 rad/s
    f) my answers so far were 0.00266 N and 0.0000266 N and both were wrong (they seem too low). I tried the equation V = Sqrt(T/u) where T is tension, and u is linear density but I must be making a mistake somewhere.
  3. Apr 17, 2006 #2
    Doc Al
    Staff: Mentor
    Check your units. Convert everything into standard units--meters, kilograms--before plugging into the equation.
  4. Apr 17, 2006 #3
    Yeah, after I triple checked my units, I realized they were wrong again. Got the correct answer of 0.266 newtons. Thanks for the reply
  5. Apr 17, 2006 #4
    nrqed
    Seems to be just a problem of units. To get the speed in m/s, you must put T in Newtons and u in kg/m. Notice that u = .22 kg/m (my guess is that you left u in g/m instead of kg/m)
    Try this and you will get a much larger tension than what you wrote above.
Loading...
Similar Threads for Quick Tension problem Date
Quick Question about Torque and Tension Jan 19, 2018
Quick Tension Problem Dec 4, 2013
Quick Question about Tension Jun 16, 2012
Need Quick Help! - Centripetal Acceleration and Tension Oct 25, 2011
Quick tension check Jul 7, 2011
