Quick way to solve this ?
  • Thread starter Quinzio
I'm trying to solve an integral, but I can't reach the book result.
I've done my work, I filled 4 sheets with integrals, but somewhere I make a mistake.
I just ask, if there a quick short way to solve the integral, to tell me or show me.
[tex] \int_{0}^{x} (x-t)e^{m(x-t)}cos(at) dt [/tex]
I have another question...
is this
[tex] \int_{0}^{x}du\int_{0}^{u} e^{m(x-t)}cos(at) dt [/tex]
equivalent to ...
[tex] \int_{0}^{x}\int_{0}^{u} e^{m(x-t)}cos(at) dt du[/tex]
Can I move the variable in an out the integral ?
Is the first form just a way to explicit which varibale belongs to which integration bounds ?
NA
NA
Answers and Replies
To avoid complications consider [tex]\int t e^t \cos t \dt[/tex] and integrate by parts ([tex]u = t[/tex],[tex]\mbox{d}v=e^t \cos t\, \mbox{d} t[/tex]). The result is awful, though.
53
is this
equivalent to ...
I'm no analyst but I would say yes. They are exactly the same and just different ways of expressing the double integral: you have an inner integral function f(u). The outer integral then integrates that function over it's bounds. Note if you switched the order of integration, say to dudt, then some changes to the limits would usually be needed. Left that to the interested reader.
vela
Staff Emeritus
Education Advisor
15,133
1,727
One thing you might try is using the fact that
[tex](x-t)e^{m(x-t)} = \frac{\partial}{\partial m} e^{m(x-t)}[/tex]
so that
[tex]\int_{0}^{x} (x-t)e^{m(x-t)}\cos(at)\,dt = \int_{0}^{x} \frac{\partial}{\partial m}e^{m(x-t)}\cos(at)\,dt = \frac{\partial}{\partial m}\int_{0}^{x} e^{m(x-t)}\cos(at)\,dt[/tex]
Also, use em(x-t) = emxe-mt and pull the factor emx out of the integral.
fzero
289
I would use Euler's identity and solve for cos:
[tex] \cos \alpha = \frac{e^{i\alpha} + e^{-i\alpha}}{2}. [/tex]
The resulting integrals are easily done by parts.
As for the second question about moving differentials, it's find as long as you do the integration in the appropriate order and don't confuse limits.
Related Threads on Quick way to solve this ?
M
  • Last Post
  • Last Post
