R.I.P. P.C.
  • Thread starter enigma
enigma
Staff Emeritus
Well, my trusty PC finally bit it. I don't know if it was a virus or simply age that did it in.
I simply turned it on, and it stalls on the bootup splash before it checks for alternate startup CDs/floppys, and before you can access the bios.
I went out and dropped 1/3 of my summer income on a new one. 2.08GHz P4, 256MB +512MB chip (yet to be installed), 120GB Drive, etc.
Now what I'm wondering: Is there any way to plug into the old one's hard drive to pull some lost files off? I did a document backup before the start of the semester, and most of the code I've written is backed up on my Zip disk which I use to do work on the school labs. The rest I have hard copy printouts, so they can be re-entered. In short, there isn't anything which I'll die without. I still would like to pull the (bought and downloaded, so not re-installable) $30 Matlab controls system package, as well as some of my favorite saved games off of it if possible.
Any ideas, tech wizards?
Answers and Replies
8,996
It sounds to me like your problem didn't have anything to do with the harddrive. So you can simply set your old hard drive to slave and there ya go. I'd do a disk check one hoocked up just to make sure though.
If you set the old hard drive up as a slave (configure the jumpers) you should be able to read off it after booting into windows on the new drive (which would be set as master).
enigma
Staff Emeritus
I think I could probably figure that out. Would it be safe to operate the system with the box open and the slave hard drive hanging out the side, or does it need to be screwed in and grounded?
Will it make a difference that the old drive is over 5 years old, and the new PC is using XP (old op. sys. was win 98). I'm guessing the bus speeds are different as well.
Probably more importantly, if something did infect the old PC, is there any chance that it will 'jump' to the new drive before I run the virus scan software on it?
8,996
It can dangle temporarily.
The old OS does not make a difference since it will not be loaded. You will just see the file structure as if it were another partition to your new drive.
There is a chance the virus could spread, but your problems doesn't sound like a virus. Just a very common hardware (most likely memory or mobo malfunction).
enigma
Staff Emeritus
thanks!
Once I get everything up and running on the new PC, I'll be sure to pester you for instructions getting the slave set up! :wink:
8,996
thanks!
ok! they instructions should be on the back of each hard drive. the jumper placement.
Suggested for: R.I.P. P.C.
