Mr Genius
- 17
Why radians are usually neglected in dimensional analysis?
Because radians are dimensionless - they are a ratio.Mr Genius said:Why radians are usually neglected in dimensional analysis?
The "ratios" I think you are referring to are not ratios - they are Quotients.RobMac said:Need to add to this explanation: "Because radians are dimensionless - they are a ratio"...of a distance by another distance. Many ratios are not dimensionless.
The angle in radians of an arc of a circle is the distance of the arc divided by the radius of the circle. By similarity, this is independent of the radius of circle used.
Did you read the Insights ariticle?I like Serena said:y problem with 'ignoring' radians
I thought I did.anorlunda said:Did you read the Insights ariticle?
All in all, I didn't find anything pertaining to my particular comment. Not in the article, nor in the comments on it.3.5 Frequency and Angular Frequency
In wave expressions, frequency, f, is the number of cycles per unit time, while angular frequency, ω, is radians per unit time. ω=2πf. Clearly ω should have dimension ΘT−1. The dimension for ff depends on whether the factor π is to be taken as an angle or as a dimensionless number performing a conversion of units. Taking f as having dimension T−1 appears to be best.
Reference https://www.physicsforums.com/insights/can-angles-assigned-dimension/
IMO the thing you're missing is the arguments for and against in the article and in the comments on the article. They apply to both angles and angular velocity.I like Serena said:Anyway, apparently I'm missing something. Can you clarify?
anorlunda said:IMO the thing you're missing is the arguments for and against in the article and in the comments on the article. They apply to both angles and angular velocity.
In AC electrical work, we typically use "angular frequency" ##2\pi{f}## 377 radians per second on a 60 Hertz system. Angular velocity would be an inappropriate term in that use.
I like Serena said:As I see it, s-1 is still very much ambiguous in dimensional analysis
Because it's not clear whether it is rad/s, or revolutions/s or just s-1 (or whatever you want to call it). The difference being a factor of ##2\pi## that we do not want to ignore.anorlunda said:I don't understand your confusion. If s (seconds) is an unambiguous unit, why is ##s^{-1}## ambiguous?
I don't know that there is any satisfactory resolution to this notational ambiguity, except to look at how the expression is being used in context. However, this is a problem when dealing with angular frequencies when the angle may or may not have bee expressed in radians, whereas this thread started out asking about the dimension of the radian itself.I like Serena said:Because it's not clear whether it is rad/s, or revolutions/s or just s-1 (or whatever you want to call it). The difference being a factor of ##2\pi## that we do not want to ignore.
I'm still not clear why it would be bad to acknowledge ##\text{rad}## as an actual unit. It seems to me that is would solve the ambiguities in dimensional analysis, since as far as I can tell, saying it's a ratio does not rid us of the ambiguities. That's because it's ambiguous what the reference is for the ratio. Am I missing something?Nugatory said:I don't know that there is any satisfactory resolution to this notational ambiguity, except to look at how the expression is being used in context. However, this is a problem when dealing with angular frequencies when the angle may or may not have bee expressed in radians, whereas this thread started out asking about the dimension of the radian itself.
Hold on, it says:anorlunda said:This article https://en.wikipedia.org/wiki/General_Conference_on_Weights_and_Measures describes the organization to make your proposal to.
I don't get a vote on those standards bodies, but if I did, I would vote yes on your proposal.
https://en.wikipedia.org/wiki/SI_derived_unit#Supplementary_units said:The International System of Units (SI) specifies a set of seven base units from which all other SI units of measurement are derived. These SI derived units are either dimensionless, or can be expressed as a product of one or more of the base units, possibly scaled by an appropriate power of exponentiation.
I believe there is still value in it. And as far as I can tell it's not mentioned explicitly in our Insight article.anorlunda said:It's like Catch 22, It is a dimensionless derived unit.
Is there any value in discussing this? We have no special insight or influence on those committees.
I got to say... That seems like a really good reason to me.I like Serena said:in a series expension of the sine
... and that sounds like a cure that's worse than the disease to me. What dimensionful combination of base units could be an improvement over the trivial (that is, dimensionless) combination that the standards body has settled on?in which case we can probably still come up with some form that it's still a unit for dimensional analysis.
Nugatory said:I got to say... That seems like a really good reason to me.
Conversely, if it's not a combination of base units, then it would have to be a base unit in its own right, which creates a different set of problems.
Nugatory said:What are we going to do with:
$$\sin x = \sum (-1)^k\frac{x^{2k+1}}{(2k+1)!}$$
And you still haven't said what combination of base units might be appropriate as an alternative to the trivial dimensionless one.
However, it can also make sense to treat it formally as a unit, e.g. when checking a physical calculation where the angles don't cancel out or in a case like this:Nugatory said:What are we going to do with:
mfb said:It doesn’t always disappear, e.g. if you use the radius of something to find a length along the circle. This becomes even more prominent if you use things like the small angle approximation.
Baluncore said:It does not matter if length is measured in metres or furlongs, the dimension will always be Length.
Likewise seconds, hours and seasons will always have the dimension of Time.
Speed can be mph, kph or metres/sec, whatever the units used, speed will have the dimension Length / Time.
It is pretty obvious that units carry dimensions, but that dimensions are not specific units.
The radian unit is a unit of measurement for angles, commonly used in geometry and trigonometry. It is defined as the angle subtended by an arc of a circle that has the same length as the radius of the circle. The radian unit is important because it allows us to measure angles in a way that is independent of the size of the circle, making it a more universal and precise unit for angle measurement.
The degree unit is another commonly used unit for measuring angles. One full rotation around a circle is equivalent to 360 degrees or 2π radians. This means that 1 radian is equivalent to approximately 57.3 degrees. The radian unit is often preferred over the degree unit in mathematical calculations because it is based on a more natural and consistent unit of measurement.
Dimensional analysis is a method of converting units and ensuring that equations are consistent with their units. In some cases, the radian unit is neglected in dimensional analysis because it is considered a dimensionless unit. This means that it does not have any physical dimensions, unlike other units such as meters or seconds. However, it is still an important unit in certain mathematical equations and should not be completely disregarded.
Yes, the radian unit can be used to measure any type of angle, whether it is acute, obtuse, or reflex. It is a unit that is proportional to the size of the angle, unlike the degree unit which is an arbitrary measurement. This makes the radian unit more versatile and applicable to a wider range of angles.
Yes, there are several advantages to using the radian unit. As mentioned before, it is a more natural and consistent unit, making it easier to use in mathematical calculations. It also eliminates the need for conversion factors when working with trigonometric functions, simplifying equations and reducing the potential for errors. Additionally, the radian unit is used in calculus and other advanced mathematical concepts, making it an essential unit for higher-level studies in science and mathematics.
