Understanding the Difference between Radiance and Irradiance
In summary, radiance and irradiance are two related but distinct concepts used to measure light. Radiance refers to the light leaving a surface, while irradiance measures the light hitting a surface. They are measured in different units and can be affected by factors such as the light source and surface material. The two are related through the inverse-square law and are used in various fields to understand the properties of objects and environments.
funcosed
37
Radiance, Irradiance?
Hi, just wondering if my understanding of the difference between these two is correct??
If radient energy is the energy transported by electromagnetic radiation then radiance is the radient energy crossing a surface per unit time that is traveling normal to the surface.
Irradience is the radient energy crossing the surface from all directions (hemisphere above the surface.
1. What is the difference between radiance and irradiance?
Radiance refers to the amount of light energy emitted or reflected by a surface, while irradiance is the amount of light energy that falls on a surface. In simpler terms, radiance measures the light leaving a surface, while irradiance measures the light hitting a surface.
2. How are radiance and irradiance measured?
Radiance is typically measured in watts per square meter per steradian (W/m2/sr), while irradiance is measured in watts per square meter (W/m2). These measurements can be taken using specialized instruments such as radiometers or photometers.
3. What factors affect radiance and irradiance?
The radiance and irradiance of a surface can be affected by several factors, including the intensity and spectral distribution of the light source, the surface material and its reflective properties, and any intervening media such as air or water.
4. How do radiance and irradiance relate to each other?
Radiance and irradiance are related through the inverse-square law, which states that the intensity of light decreases proportionally to the square of the distance from the source. This means that as the distance from a light source increases, irradiance decreases faster than radiance.
5. What applications is radiance and irradiance used for?
Radiance and irradiance are important concepts in fields such as optics, astronomy, and remote sensing. They are used to measure and characterize light from various sources, which can help in understanding the physical properties of objects and environments.
13K
  • Thermodynamics
  • Other Physics Topics
  • Classical Physics
9K
