Radians Angular Displacement
Coverting Cord length to radians and the other problem is: A ball Radius = 12 CM, rolls 15 M, across the gym floor. Through what angle does the ball rotate?
We just started this today and im very confused by it. the other question is converting 11.6 CM Chord Length into Radians.
O=s/r
I dont know how to convert chord length to radians and on the next one I converted 15M to centimeters and then i plugged it into the formula doing 1500CM/12CM which gets me 125 Radians and then I did 125(180/3.14) and got 7165 Degrees which cannot be correct.
Answers and Replies
NascentOxygen
Staff Emeritus
1,072
If it makes many rotations, then angle of rotation will exceed 360°.
lightgrav
1,248
30
cord length, as if a cord is wrapped around the circumference?
or chord length, as a straight line from one circumference point to another?
(Your small ball does rotate 125 radians to roll 15 meters.)
A cord as in straight line across it
Cord length as in a straigt line across it
lightgrav
1,248
30
did you draw it? I suggest also draw 2 radial lines from the center to those circumference points . . . maybe one in the center of the chord, also.
I did draw it and i have a problem worked out to get the cord i just cant figure out how to work back words from it I know have to cord is 5.8 CM and there is a 90 Degree angle there am i supposed to do -TAN(Y/X) ?
lightgrav
1,248
30
YES! we love right triangles! (don't forget the other half chord)
alright cool thanks
Related Threads on Radians Angular Displacement
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
105K
  • Last Post
