Homework Help: Radians to seconds?
  1. Feb 20, 2013 #1
    Given an equation such as f(t)=Rsin(ωt + θ)
    find the value of f(t) when t=5s
    2. Relevant equations
    N/A
    3. The attempt at a solution
    What I'm not understanding is that generally a function sin(ωt + θ) describes what happens when the angle t changes. However the question gives t in seconds.
    I'm pretty sure it is as simple as substituing 5 in for t but i'm not certain.
    My assumption is that knowing the frequency (ω/2∏ - I think!) allows you to know how many cycles occur in 1 second.
    So the frequency x t (5 x ω/2∏) gives you number of waves in 5 seconds - converting this to an angle by multiplying by 2∏ again leaves you with 5ω (ωt).
    Therefore seconds = radians?
    Can somebody confirm? Also - is my expression for frequency correct?
  3. Feb 20, 2013 #2
    Ray Vickson
    You are mixing up angles and angular rates. The parameter ω has units of radians per second ant time t is in seconds, so ωt is in radians.
  4. Feb 20, 2013 #3
    LCKurtz
    The units on ##\omega## would be radians/second; it's the angular velocity. Multiply by t seconds and you get ##\omega t## in radians, add that to ##\theta## in radians and the units of the argument are radians. Then take the sine of it. :smile:
  5. Feb 20, 2013 #4
    Nooo - sorry I should have seen this coming...
    I chose ω arbitrarily to represent an angle. Yes I know ω is angular velocity usually but think of it as just an angle in radians (I should have picked a less confusing symbol)
    In any case it being the angular velocity wouldn't make any sense in what I had explained previously. I am simply asking if my assumption regarding the frequency and time is correct?
    I.e. is substituing 5 in for t going to give me the right answer!
  6. Feb 20, 2013 #5
    Mark44
    Staff: Mentor
    In your expression sin(ωt + θ), both θ and ωt are angles, typically in radians, so ωt + θ also represents an angle.
    Assuming you are measuring angles in radians, the only way that ωt can represent an angle when t is time is for ω to represent radians/time.
  7. Feb 20, 2013 #6
    I see what you are saying - this is a question for a course in electrical engineering. So presumably in the general case for sine wave signals the coefficient of t is always the angular velocity of the wave?
    So would the following statements be correct:
    For the function Rsin(40∏t + ∏)
    the frequency is 40∏/2∏ = 20Hz
    and the period would be 2∏/40∏ = 0.05
  8. Feb 20, 2013 #7
    Mark44
    Staff: Mentor
    Yes.
  9. Feb 20, 2013 #8
    tiny-tim
    hey there, fonz! :cool:
    what's inside a sin (or cos or log or exp) must be an ordinary number
    (a radian is an ordinary number)
    sooo, if you have a time inside a sin (or log etc), it must be multiplied by a 1/time (or radian/time) :wink:
  10. Feb 20, 2013 #9
    Right sussed that then.
    Thanks for all your help and contributions
