How is radioactive contamination decontaminated?
  • Thread starter aquitaine
  • Tags
    Radioactive
In summary, decontamination of radioactive waste depends on the nature of the contamination. For external contamination, steps may include removing affected clothing, rinsing and flushing affected skin, using adhesive tape or abrasive soap, and applying chemical treatments. For internal contamination, monitoring and disposal of waste material is necessary.
aquitaine
30
Lets say somehow something or someplace gets contaminated with radioactive waste, how is it decontaminated?
Depends on what the nature of the subject and radioactive material. If you are talking about a hot particle on someone's clothes or skin, you could use sticky tape. If the problem is radioactive liquid spills on a surface, you need high pressure sprays or chemicals. For internal contamination of a person, there isn't much you can do unless the isotope has a biological function that can be flushed out (e.g. iodine).
OK, let's suppose you get some radioactive contamination on you. It isn't fantastically dangerous supernatural evil magic, it's just like getting some dirt on you. You wash it off. Then re-check with a detector to see if there is any radioactivity left.
Normally it would be a wash or chemical treatment, or it could be an abrasive process, and the solution would be passed through filters to collect and concentrate the radioactive material. Alternatively, the contaminated area or part could be simply removed from that which is not contaminated. The radioactive material would be collected and shipped to a site where radioactive material is buried.
The process used depends on the nature of the contamination.
You wash! It's not that uncommon if you work at a 40 year old Nuclear utility like I do. Detection capability is very sensitive these days. Plutonium contamination has to be treated with care as you wouldn't want to break the skin and allow internal contamination.
PS You never seen the film Silkwood with Meryl Streep? :smile:
So if a dirty bomb went off that contaminated part of an urban area they would wash it down? Interesting, thanks.
From MIT's "Technology Review":
http://www.technologyreview.com/energy/13651/
The author is a Professor of Physics at UC-Berkeley.
He is the author of the book "Physics for Future Presidents"
http://muller.lbl.gov/
Dr. Gregory Greenman
As a radiation health tech in the nuclear navy I can tell you if it is external, the steps are in approximate order of trying to solve the problem:
1) Remove and bag affective clothing (control as radioactive material [RAM])
2) Rinse/flush affected skin with water. 'Pat' dry to keep from rubbing anything in, control waste water and dispose of towelettes as RAM. Rubbing can cause irritation and/or create small abrasive cuts in the skin allowing potential contaminates to enter the blood stream.
3) Adhesive tape. Dispose of as RAM. Ensure skin does not become enflammed as this can embed potential contaminates into deeper skin tissue and or allow it to enter the blood stream.
4) Abrasive soap. (you get the disposal/control of materials/liquids by now)
5) Chemical treatments.
6) If inhaled, you'll need to undergo internal monitoring.
7) If ingested, any 'waste' "you" generate, must be bagged and controlled as RAM... my personal favorite... lol.
1. What is radioactive decontamination?
Radioactive decontamination is the process of removing or reducing radioactive materials from a contaminated area or object. This is done to protect people and the environment from the harmful effects of radiation.
2. How is radioactive decontamination performed?
The specific methods used for radioactive decontamination can vary depending on the type of contamination and the affected area. Some common techniques include physical removal through scrubbing or scraping, chemical treatments, and radiation-based methods such as ion exchange or irradiation.
3. Who performs radioactive decontamination?
Radioactive decontamination is typically performed by trained and qualified professionals, such as nuclear scientists, engineers, and technicians. These individuals have the knowledge and expertise to safely handle and remove radioactive materials.
4. What are the potential risks of radioactive decontamination?
The main risk associated with radioactive decontamination is exposure to radiation. This can be minimized by following proper safety protocols and using appropriate protective equipment. There is also a risk of spreading contamination if the decontamination process is not performed correctly or if proper disposal methods are not followed.
5. How long does radioactive decontamination take?
The duration of radioactive decontamination can vary depending on the type and extent of contamination, as well as the methods used for decontamination. Some small-scale decontamination processes can be completed in a matter of hours, while larger and more complex decontamination projects may take weeks or even months.
  • Nuclear Engineering
