Answer Age of Rock: 1.7*10^9 Years
In summary, the problem asks to determine the age of a rock containing the radioactive isotope Rb-87, given its initial number of atoms and the number of decay products per kg. Using the equation N(t)=N_0(\frac{1}{2})^{t/T_{1/2}}, where N(t) is the current number of atoms, N_0 is the initial number of atoms, and T_{1/2} is the half-life, the age of the rock can be calculated. However, based on the given data, the calculated age is different from the answer provided in the key, indicating a possible error in the data.
triac
Hi!
I'm stuck on this one too.
"A rock contains the radioactive isotope Rb-87. A piece of this rock contained 2,05*10^20 Rb-87 atoms and 8,25*10^20 decay products per kg. The half-life of Rb-87 is 47*10^9 years. How old is the rock?"
[tex]N(t)=N_0(\frac{1}{2})^{t/T_{1/2}} [/tex]
No nuclei (or atoms) disappear, they only decay. Therefore, the initial number of Rb-87 atoms must have been 2,05*10^20+8,25*10^20 per kg. Let's assume that we have a sample of 1 kg (the mass will change with decay, but not the number of atoms, so it doesn't matter).
Now, let x be its age. Then we can write
2,05*10^20=(2,05*10^20+8,25*10^20)(1/2)^(t/T_{1/2}) which gives us that x is approximately 22,9*10^9 years. However, in the key it says 1,7*10^9 years. What's wrong here?
Is your question is fully written?
Please don't use comma or dot in numbers..? it is confusing..(Germany it is common, using comma for dot)
in your case 't' should be age..but why you introduced 'x'..
is this problem is solved?
[tex]
47\times10^9 {\rm or} 4.7\times10^9
[/tex]?
I don't think you have all the data written down correctly, if 1.7*10^9 is the answer. If you start with 10.3 atoms after one half life there would be 5.15 atoms left and 47*10^9 years would have past but you have fewer atoms left and an answer of less time which is clearly wrong. Unless i haven't understood the question
1. What does "1.7*10^9 Years" mean in terms of the age of rock?
The notation "1.7*10^9 Years" represents 1.7 billion years. This is the estimated age of the rock, based on scientific methods such as radiometric dating.
2. How do scientists determine the age of rock?
Scientists use various methods such as radiometric dating, which involves measuring the decay of radioactive elements within the rock, as well as studying the layers and composition of the rock to determine its age.
3. Why is it important to know the age of rock?
Knowing the age of rock helps scientists understand the Earth's history and the processes that have shaped it. It also allows us to better understand the evolution of life on Earth and make predictions about future geological events.
4. Can the age of rock change over time?
The age of rock does not change over time, as it is a fixed measurement of the time that has passed since the rock was formed. However, new scientific discoveries and advancements may lead to more accurate age estimations.
5. How accurate is the age estimation of rock?
The accuracy of age estimations for rock can vary depending on the methods and data used. In general, the margin of error can be up to a few million years. However, with advancements in technology and more precise methods, the accuracy of age estimations continues to improve.
