Homework Help: Radius of a raindrop
  1. May 5, 2017 #1
    Using the viscosity of air as 1.8x10-5Pa s, and the density of water as 1x103kg m-3, find the radius of a raindrop travelling at a terminal velocity of 7.05ms-1. Assume Stokes law can be used.
    The problem is finding the density of air, I could use F = 6rvπη but I don't know F, because it says in a previous question to assume that in D + U = W, to assume U is negligible, and I don't know the weight, because I don't know the mass or volume of the raindrop.
    2. Relevant equations
    r = sqrt((9ηv)/(2g(ρ-σ)))
    3. The attempt at a solution
    Without a density of air, I get 9.31x10-5m, but that would be wrong since the density of air is not being included.
  3. May 5, 2017 #2
    BvU
    2017 Award
    Density of air is a small correction, so you can use the ideal gas law to find its approximate value.
  4. May 5, 2017 #3
    ehild
    Google "density of air" .(It is about 1.225 kg/m3)
    And check your numerical result.
  5. May 5, 2017 #4
    In your judgment, is buoyancy going to contribute significantly to the net force on the raindrop?
  6. May 6, 2017 #5
    If by buoyancy you mean upthrust, then no, a previous part of the question says it is neglibible. So its just F = W.
  7. May 6, 2017 #6
    ehild
    It is not correct, but not because of neglecting the density of air.
Have something to add?
Draft saved Draft deleted
