Rail Gun Propulsion: Perverting a Rail Gun Into a Rocket?
In summary: While a high-power electric ion thruster may have an advantage over a high-power chemical rocket, that advantage is only true when the rocket is powered entirely by a high-power electric ion thruster. This is because a chemical rocket can also use the stored energy of the fuel (in the form of chemical energy) to provide some of the power for the rocket.
schonovic
85
Is it possible to pervert a rail gun into a rocket? I'm understanding that plasma conducts electricity. If i could supply a rail gun with constant current and send in a constant feed of hot plasma into the rail gun would the machine send out plasma at high enough speeds to be used as a rocket engine?
Bobbywhy
No, none of those are what I am describing. I'm talking about a regular rail gun except instead of a solid round being propelled to high velocities I'm having heated plasma propelled to high velocities. A constant current being applied to the rail and a constant supply of plasma being fed into the system. What I'm asking is will this work? Will a regular rail gun propel plasma the same way it propels a solid round?
In theory, the rail gun would accelerate the plasma, maybe even more efficiently than a slug.
In practice, the plasma needs to be confined and may not touch the power leads for the rail gun, lest the propulsion effect get short circuited.
Solving those problems may drive you back to the approaches Bobbywhy has noted above.
Thanks etudiant and thank you Bobywhy. I'll refer to your help.
I'm sure your concept would work, but why have a whole separate rail mechanism accelerating the plasma, when the plasma's heat and pressure already do this? And thus you have the aforementioned ion thruster...
Lsos
I just thought it would dramatically increase thrust capacity.
You could use a rail gun to serve as the first stage of a rocket-propelled device which would then ignite the second stage at the appropriate time. It would eliminate having those pesky boosters falling into the ocean.
your idea is sound and there is some existing tech however this system would require HUGE amounts of energy to operate at anything approaching thrust capacity, so if you have unlimited power supply then sure, but in a practical application standard solid or liquid state rocket fuel will offer the most force per pound and thus be the most efficient for a rocket (chemical energy storage is the best known so far), that said if you can mount your system to the ground, say for a plasma weapon or a cutting tool, then you might have something that could function... perhaps even powering it with solar or wind... haha you could have a green gun...
Deotheophilus, "standard" chemical rockets might be most efficient when it comes to thrust/energy, but they most certainly are not when it comes to thrust/mass. Since mass is often the limiting factor once in space, a brute "force/ pound" approach is not going to give you the most speed.
I'm not arguing that for slow long distance travel (E.G space) something that requires minimal fuel, such as the high energy plasma thrusters disused here https://en.wikipedia.org/wiki/Plasma_propulsion_engine however the previous article claimed that these were not what was in mind, instead it is assumed that by rocket schonovic intends this as a on Earth or similar body weapon propellant, and in this case a chemical rocket will provide more energy/mass than you could hope for in any electric storage system I know to exist today, because of this my statement stands, a chemical rocket will still offer a more efficient option, in Layman's terms "More Bang for Your Buck"... (this might account for the reason NASA and now SpaceX use chemical thrusters to achieve escape velocity and only switch to ion thrusters when in the vacuum of space while powering it with the photoelectric effect) further thrust/energy advantage would not be necessarily true of a chemical rocket, they are merely capable of storing more energy/mass...
1. What is a rail gun and how does it work?
A rail gun is a type of electromagnetic weapon that uses the principles of electromagnetism to accelerate a projectile to hypersonic speeds. It consists of two parallel rails connected to a power source, with the projectile placed between the rails. When a high current is passed through the rails, a strong electromagnetic field is created that pushes the projectile forward with immense force.
2. How can a rail gun be used for rocket propulsion?
A rail gun can be adapted for use as a rocket propulsion system by attaching a rocket engine to the back of the projectile. As the projectile is accelerated down the rails, the rocket engine ignites and provides additional thrust to propel the projectile even faster. This allows the rail gun to achieve even higher velocities and potentially escape Earth's atmosphere.
3. What are the advantages of using a rail gun for rocket propulsion?
One of the main advantages of using a rail gun for rocket propulsion is its potential for achieving much higher velocities than traditional chemical rockets. This could significantly reduce travel time for space missions and make it possible to reach destinations that are currently inaccessible. Additionally, rail guns are powered by electricity, which is a more efficient and cleaner energy source than the traditional rocket propellants.
4. What are the challenges of using a rail gun for rocket propulsion?
One major challenge is the immense amount of energy required to power a rail gun. The power source must be capable of delivering extremely high currents in a short amount of time, which can be difficult and expensive to achieve. Additionally, the high G-forces experienced by the projectile during acceleration could potentially damage sensitive cargo or equipment.
5. What are the potential applications of rail gun propulsion?
Rail gun propulsion could have a wide range of applications, including launching payloads into space, propelling spacecraft to other planets or moons, and even powering interstellar travel. It could also be used for military purposes, such as launching hypersonic missiles or defending against incoming missiles. Additionally, the technology could have commercial applications in transportation, such as high-speed trains or aircraft.
  • Mechanical Engineering
  • Other Physics Topics
  • Aerospace Engineering
  • Electrical Engineering
