Ramp frictional force
  • Thread starter jfk313
jfk313
Find the frictional force (magnitude and direction) on the crate if the crate is sliding up the ramp.
Frictional force= ?
μk = 0.30
μs = 0.74
mass=10.0 kg
angle of incline 30° to the horizontal
fk=uk * N
I tried doing this problem by drawing t he free body diagram and creating another triangle to find frictional force, as seen in the picture
https://www.youtube.com/watch?v=https://www.youtube.com/watch?v=
. i tried solving for the frictional force by multiplying the kinetic coefficient of friction, gravity and mass with sin(30).... I found out from a friend that cos(30) would give you the correct answer, but I not sure why. So I wanted to understand why the sin(30), giving you the parallel force of friction, is not correct when trying to solve this problem.
Answers and Replies
Yosty22
185
When you draw out the freebody diagram, try making the x-axis the ramp 30 (tilted axis). Then, break up the weight vector into its x and y components, and you should be able to see that mgsin(\theta)is a force in the same direction as friction, but it is NOT friction. Friction is a separate force on the free body diagram all together.
Yosty22
185
The mgsin(\theta) term is NOT the parallel force of friction. It is the box's parallel (x-component) of weight.
Suggested for: Ramp frictional force
  • Last Post
  • Last Post
