What Are the Ranges of Functions g and h and Their Composite Functions?
In summary, the ranges of g and h are {-1,1} and {-1,1,2}, respectively, and the composite function h ° g is equal to g ° h.
MorallyObtuse
45
Help needed.
Functions g and h are defined as follows:
g : x → 1 + x x ∈ R
h : x → x² + 2x x ∈ R
Find i.) the ranges of g and h,
ii.) the composite functions h ° g and g ° h, stating their ranges.
Not sure how this is to be done help needed, please.
2. The attempt at a solution
i.) range of g => R = {y : y ∈ R}
1 + x = 0
x = -1
1 - 2 = -1
-b/2a = -2/2 = -1
range of h => R = {y : y ≥ - 1, y ∈ R}
The way to do this explicitly, would be to simply give the formula for h o g and g o h, which will give you two quadratic functions again.
But you can also find it by argument. For example, consider h o g. You take some x and apply g. What are the possible values y that you get. Then apply h. What can y map to?
MorallyObtuse said:
Help needed.
g : x → 1 + x x ∈ R
1 + x = 0
x = -1
1 - 2 = -1
-b/2a = -2/2 = -1
h(x)= [itex]x^2+ 2x= x^2+ 2x+ 1- 1= (x+1)^2- 1[/itex]
I presume that is why you were looking at "1+ x= 0"!
Now, g(x) can be any number so h(g(x)) can be what?
h(x) must be larger than or equal to 1 so g(h(x)) can be what?
Not sure how much of a difference this is:
g : x |→ 1 + x x ∈ R
h : x |→ x² + 2x x ∈ R
This would be the range of h(x)=> [itex] x^2 + 2x = x^2 + 2x + 1 - 1 = (x + 1)^2 - 1[/itex]
and my range for g is correct?
h(g(x)) can be any number. R = {y: x ∈ R}
g(h(x)) can be larger than or equal to 1. R = {y : ≥ - 1, y ∈ R}
Your result for h(x) already was correct (it's {y | y ≥ -1}).
Halls was just pointing out that h(x) = g(x)2 - 1, I suppose (which you could also have used to obtain the same result).
Note that h(g(x)) means you are first evaluating g on x. This can give you any number, which you plug into h...
What is the range of a function?
The range of a function is the set of all possible outputs or values that the function can produce.
How is the range of a function different from the domain?
The domain of a function is the set of all possible inputs or values that can be plugged into the function, while the range is the set of all possible outputs that result from those inputs.
How do I find the range of a function?
To find the range of a function, you can either graph the function and identify the highest and lowest points on the graph, or you can use algebraic methods to find the minimum and maximum values of the function.
Can a function have an infinite range?
Yes, a function can have an infinite range if it continues to produce larger and larger values without ever reaching a maximum or minimum point.
Can a function have a finite range?
Yes, a function can have a finite range if it reaches a maximum or minimum point and does not produce any values larger or smaller than that point.
