Solving for x in P(x) = √6+5x-x2
  • Thread starter Wa1337
Therefore the vertex is (2.5,-12.25). The range is all real numbers greater than or equal to -12.25.In summary, the conversation discusses finding the domain and range of the function P(x) = √6+5x-x2, with one person clarifying the use of parentheses to avoid confusion. The solution involves finding the domain by setting the expression inside the square root to be greater than or equal to 0, and finding the range by determining the vertex of the parabola formed by the function. The final conclusion is that the domain is all real numbers, and the range is all real numbers greater than or equal to -12.25.
Wa1337
33
P(x) = √6+5x-x2
P(x) = √6+5x-x2
-x2+5x+6 >/= 0
x2-5x-6 </= 0
(x-6)(x+1) </= 0
Do you mean [itex]P(x) =\sqrt{6+5x-x^2}\,?[/itex]
If so, then use parentheses to make things clear.
P(x) = √(6+5x-x2).
Otherwise it looks like you have [itex]P(x) =(\sqrt{6})+5x-x^2\,?[/itex]
Wa1337 said:
P(x) = √6+5x-x2
P(x) = √6+5x-x2
-x2+5x+6 >/= 0
x2-5x-6 </= 0
(x-6)(x+1) </= 0
What you have done will allow you to find the domain of P(x).
To find the range, find the vertex of the parabola of f(x) = 6+5x-x2 . Then proceed from there.
In vertex form it is y=(x-2.5)2-12.25
1. How do I solve for x in P(x) = √6+5x-x2?
To solve for x in this equation, you can use the quadratic formula or factor the equation to find the roots. You can also use a graphing calculator to visualize the solution points.
2. Why is it important to solve for x in this equation?
Solving for x in this equation helps us determine the values of x that make the equation true. This is important for finding the solutions to real-world problems and understanding the behavior of functions.
3. Can this equation have more than one solution for x?
Yes, this equation can have up to two solutions for x. This is because it is a quadratic equation, which can have two real solutions, one real solution, or no real solutions depending on the discriminant.
4. What does the graph of this equation look like?
The graph of this equation is a parabola that opens downwards and crosses the x-axis at the x-intercepts, which are the solutions for x in the equation.
5. Are there any restrictions on the values of x in this equation?
Yes, since the equation contains a square root, the value inside the square root (6+5x-x2) must be greater than or equal to 0. This means that the values of x must fall within a certain range for the equation to have real solutions.
