Ranges of Projectiles With and Without Drag
In summary: Okay, so what would be the difference between "80 degrees to the horizon" and "80 degrees to the zenith"?In summary, the conversation discusses a lab using an online projectile simulator, where the range of projectiles were measured at different initial speeds and with and without air resistance. The resulting graphs showed a logarithmic trend for the case without air resistance and an exponential trend for the case with air resistance. The conversation also touches upon the importance of considering air resistance in projectile motion calculations and the difference between launching a projectile towards the horizon or the zenith.
ProfuselyQuarky
588
I recently completed a lab using an online projectile simulator about the range of projectiles. I launched a projectile with different initial speeds (5 m/s, 10 m/s, 15 m/s, 20 m/s, and 25 m/s). For each trial, I did the launch with and without air resistance and I plotted Range (with Air Resistance) vs. Initial Speed and Range (without Air Resistance) vs. Initial Speed onto my calculator. The former graph was logarithmic and the latter graph was exponential. Why is this so? This has nothing to do with my homework; I just wanted to know.
Exponential, you say?
The case without air resistance is easy to calculate. Go ahead and do that, and see if it agrees with the simulator. Maybe the simulator is wrong.
What do you mean "calculate"? What would you like me to calculate?
EDIT: All I want to know is why one of the graphs is logarithmic while the other is exponential.
Calculate the range of the projectile, both with and without considering the effect of drag or air resistance.
The equations of projectile motion neglecting air resistance are used quite a bit in intro. physics courses. If you go to the HW forums here at PF for Intro Physics, you'll see that users have quite a few questions where projectile motion is discussed without considering air resistance. Not so many questions, however, assuming that air resistance cannot be neglected.
Likes ProfuselyQuarky
The range will be strongly dependent on initial direction.
Yes, obviously, the range of a projectile is shortened when drag is accounted for. I know how to use a variation of the kinematic equations to calculate that sort of stuff without regard for drag, but I'm not so sure what to do with the air resistance. The drag coefficient used was 1 and the altitude was set to 0 . . .
The initial angle was 80 degrees. The simulator did not give an option on actual direction. I designed the experiment so that the only variables were the initial velocities and the range itself.
80 degrees to the horizon or the zenith?
I don't think you are expected to analytically calculate the range with air resistance, but you should be able to calculate it without air resistance, even in a starting physics class. Compare that to the simulation to test out the simulation, and then form some conclusions about the air resistance case.
For the purposes of range calculations, drag and air resistance are the same thing: the amount of drag is proportional to the speed of the projectile, usually to the second power.
The following article shows how the range of a projectile is affected when air resistance or drag varies as the speed of the projectile, rather than the square of the speed:
http://farside.ph.utexas.edu/teaching/336k/Newtonhtml/node29.html
Ah, I'm guessing zenith? The angle only determined the angle in which the projectile was launched.
Yeah, I know. I already did all that. For this specific assignment, I was the one who was creating the data analysis questions to be answered. This entire thread is because of curiosity. I guess that the Range (without Air Resistance) vs. Initial Speed graph was exponential because the range of the projectile increased at a faster pace compared to the Range (with Air Resistance) vs. Initial Speed. I wish there was some way to show you my graphs/charts/sample calculations.
I actually thought that drag and air resistance were synonymous terms always . . .
Thank you for the article. I’ll look at it in depth, but right now, by just skimming through, it looks like something that I am capable of doing.
The angle determines the range in a significant way.
For a given initial speed, the range can be anywhere from zero to some maximum values, depending on the angle.
Okay, so what would be the difference between "80 degrees to the horizon or the zenith"?
In other words, is it pointing almost straight up, or pointing just above level with the ground? You said 80 degrees, but that is ambiguous.
80 degrees meaning almost straight up—10 degrees off from being a straight 90 degree angle upward.
1. What is the difference between ranges of projectiles with and without drag?
The range of a projectile without drag is the maximum distance it travels in a vacuum, while the range of a projectile with drag takes into account air resistance and is therefore shorter.
2. How does air resistance affect the range of a projectile?
Air resistance, or drag, slows down the projectile as it moves through the air, causing it to lose velocity and therefore reducing its range.
3. What factors influence the range of a projectile with drag?
The range of a projectile with drag is influenced by its initial velocity, the angle at which it is launched, the mass and size of the projectile, and the air density and wind conditions.
4. Can the range of a projectile with drag be predicted accurately?
Yes, the range of a projectile with drag can be predicted using mathematical equations that take into account the various factors that affect its trajectory and distance traveled.
5. How does the shape of a projectile impact its range with and without drag?
The shape of a projectile can affect its drag coefficient, which is a measure of its aerodynamic properties. A streamlined shape will have a lower drag coefficient and therefore a longer range compared to a less streamlined shape with a higher drag coefficient.
17K
  • Mechanics
