Can a Raser Amplify Radioactive Rays Like a Laser?
  • Thread starter desert fox
  • Tags
    Laser
In summary, the main issue with using gamma rays for amplification is that there are few sensible mirrors that can handle the wavelength.
desert fox
Nice to meet all of you :smile:
We know that laser is amplified light.
There's possible if amplify the radioactive ray (alpha, beta, or gamma) with the same procedure like the laser mechanism? :confused:
Science news on Phys.org
Gama rays are electromagnetic - like light - and could theoretically be amplified in the same way (though I suspect it wouldn't be practical due to the short wavelength).
Alpha and beta radiation are particles and you can't amplify a particle.
Welcome to PF!
Hi desert fox! Welcome to PF! :smile:
Hi russ! :smile:
Alpha particles are bosons, so why couldn't we amplify a beam of them in the same way? :confused:
(1) Charge conservation.
(2) How are you planning on creating a population inversion?
"Matter lasers" happen to be an active area of research, in the laser cooling / BEC research community:
http://everything2.com/e2node/atom%20laser
It isn't necessary to actually create particles, you just need to amplify the number of particles that are in a specific state, using an available reservoir of the particles.
I stand corrected!
russ_watters said:
Gama rays are electromagnetic - like light - and could theoretically be amplified in the same way (though I suspect it wouldn't be practical due to the short wavelength)...
Just for fun, I searched through Wikipedia looking for the phrase "gamma-ray laser" and found a couple more exotic possibilities -- using excited nuclei in the place of excited atoms, or using positronium annihilation. It all seems very speculative, but possibly more practical than trying to apply the standard procedure to such short wavelengths.
http://en.wikipedia.org/wiki/Laser
http://en.wikipedia.org/wiki/Induced_gamma_emission
russ_watters said:
I stand corrected!
On the other hand, this is cold, low-kinetic-energy matter being used for matter-lasers. Not what you typically find as radioactive decay products.
Are the product of Gamma ray amplified more dangerous than the ordinary gamma ray?
If they existed, I imagine gamma rays from a gamma-laser would be more dangerous just as laser beams are more dangerous than ordinary light. Mainly because the energy would be more concentrated.
The main problem is the lack of sensible mirrors in the gamma range.
Free electron lasers however are able to produce light in the vacuum UV to soft x-ray range and even a bit beyond (see for example FLASH at the Desy in Hamburg). The drawback is that these lasers rely on self amplified stimulated emission, which uses just the emission of microbunched electrons going through an undulator once. Therefore the amplification is there, but the coherence time is very low.
Low coherence time = short range / rapid dispersion?
Coherence time is defined by the inverse spectral width, so low coherence time means most of all, that the emission is spectrally rather broad as the coherence times can be as low as 0.3 fs.
The temporal profile of the intensity will also show a lot of spikes. See for example the Desy-FEL page here for what the beam looks like: http://hasylab.desy.de/facilities/s...rotron_radiation_to_a_sase_fel/index_eng.html
1. What is a Raser (Radioactive Laser)?
A Raser, short for radioactive laser, is a type of laser that uses radioactive materials as the lasing medium. It produces a highly concentrated beam of radiation that can be used for various applications, such as medical treatments, scientific research, and industrial processes.
2. How does a Raser work?
Similar to traditional lasers, a Raser works by stimulating atoms in the radioactive material to release photons, which then bounce back and forth between two mirrors. This amplifies the radiation and produces a highly directional and coherent beam of light.
3. What are the advantages of using a Raser?
Rasers have several advantages over traditional lasers, including higher power output, longer wavelengths, and the ability to operate at room temperature. They also have a wider range of applications, such as in nuclear fusion research and cancer treatment.
4. Are there any safety concerns with using a Raser?
Yes, there are safety concerns when working with radioactive materials. Proper precautions must be taken to ensure the safe handling and disposal of the radioactive materials used in a Raser. Additionally, the concentrated beam of radiation produced by a Raser can be harmful if not used properly.
5. What are the current developments in Raser technology?
Scientists are continuously researching and developing new types of Raser that use different radioactive materials and have unique properties. They are also exploring potential applications for Raser technology, such as in nuclear waste management and space propulsion.
