Solving Rate Law Problem: Find k for A--> Products
  • Thread starter firyace
  • Tags
    Law Rate
In summary, the problem is about a reaction that follows the Rate Law, Rate = k[A]^2. The initial concentration of A is 2.00M and it takes 1 hour for 60% of A to react at 25 celsius. The goal is to find the value of the rate constant k at this temperature. One approach is to use the equation for a 2nd order reaction, 1/[A] = 1/[Ao] +kt, and plug in the given numbers to solve for k. However, the expected answer of 2.1*10^-4 M^-1 s^-1 may not match the answer obtained using this method. It is possible to mathematically derive the equations
firyace
I have given this problem:
The reaction:
A--> Products
Follows the Rate Law, Rate = k[A]^2. When the initial concentration of A is 2.00M, it takes 1 hour for 60% of A to react at 25 celsius. What is the value of the rate constant k at this temp?
-I try to sub 2.00 into A, and (2.00 * .6)/3600 (in seconds) for rate, but I always get a different answer:bugeye:
-the answer is suppose to be 2.1*10^-4 M^-1 s^-1
Many thanks!
Are you familiar with the equations for 0 order, 1st order and 2nd order reactions? It is possible to mathematically derive them, but it seems like you are usually given them in a data sheet.
The equation for a 2nd order reaction such as the one you have been given is
1/[A] = 1/[Ao] +kt
From there all you need to do is stick in your numbers. You have been given all of the data you need to put numbers in for the initial and final concentration, and are given a time. Got it?
Based on the given information, we can use the integrated form of the rate law to solve for the rate constant (k). The integrated rate law for a first-order reaction is ln[A]t = -kt + ln[A]0, where [A]t is the concentration of A at time t, k is the rate constant, and [A]0 is the initial concentration of A.
In this case, we know that [A]0 = 2.00 M and [A]t = 0.60 * 2.00 M = 1.20 M (since 60% of A has reacted). We also know that t = 1 hour = 3600 seconds.
Substituting these values into the integrated rate law, we get:
ln(1.20 M) = -k * 3600 s + ln(2.00 M)
Solving for k, we get:
k = (ln(1.20 M) - ln(2.00 M)) / (-3600 s)
k = -0.5108 / (-3600 s)
k = 1.4 * 10^-4 s^-1
However, the given answer is in units of M^-1 s^-1, so we need to convert our answer to match. Since the units of concentration are M, we can multiply our answer by 1/M to get the correct units:
k = 1.4 * 10^-4 s^-1 * 1/M
k = 1.4 * 10^-4 M^-1 s^-1
This is close to the given answer of 2.1 * 10^-4 M^-1 s^-1, but not exactly the same. This could be due to rounding errors or slight differences in the given values. However, the method used to solve the problem should be correct.
What is the rate law for a chemical reaction?
The rate law for a chemical reaction is an equation that relates the rate of the reaction to the concentrations of the reactants. It is typically written in the form of Rate = k[A]^m[B]^n, where k is the rate constant and m and n are the reaction orders for reactants A and B, respectively.
How do you determine the rate constant (k) for a reaction?
The rate constant can be determined experimentally by measuring the initial rates of the reaction at different concentrations of the reactants and plotting them on a graph. The slope of the graph will give the reaction order (m or n), and the intercept will give the value of the rate constant (k).
What is the significance of the rate constant (k) in a rate law?
The rate constant (k) is a proportionality constant that relates the rate of the reaction to the concentrations of the reactants. It is a measure of how fast a reaction occurs and is unique for each chemical reaction. The larger the value of k, the faster the reaction will proceed.
How do you solve for the rate constant (k) in a rate law problem?
To solve for the rate constant (k), you will need to use initial rate data from experiments and plug them into the rate law equation. Then, you can use algebra to solve for the value of k. It may be helpful to create a table to organize the data and make the calculations easier.
What are the units for the rate constant (k)?
The units for the rate constant (k) depend on the overall reaction order (m + n). For a zero-order reaction (m + n = 0), the units of k are concentration/time (M/s). For a first-order reaction (m + n = 1), the units of k are 1/time (1/s). For a second-order reaction (m + n = 2), the units of k are 1/concentration*time (1/M*s).
