Rate of change problem
  • Thread starter Incog
Incog
A water tank is built in the shape of a circular cone with a height of 6 m and a diameter of 10 m at the top. Water is being pumped into the tank at a rate of 2m[tex]^{3}[/tex]
per minute. Find the rate at which the water level is rising when the water is 2 m deep.
Volume of a cone - [tex]\frac{1}{3}[/tex] [tex]\Pi[/tex] r[tex]^{2}[/tex] h
Surface area of a cone - [tex]\Pi[/tex] r s + [tex]\Pi[/tex] r[tex]^{2}[/tex]
[tex]\frac{dV}{dt}[/tex] = 2m[tex]^{3}[/tex]/min
I think I have to find [tex]\frac{dh}{dt}[/tex] but other than that I'm completely lost.
Answers and Replies
ice109
1,714
what is h as a function of v?
Incog
I'm not sure I understand.
TMM
92
Can you relate r and h with the knowledge that the tank is a cone?
Feldoh
1,342
What both ice109 and TMM are trying to say is that you have two variables since
[tex]V = \frac{1}{3}{\pi}r^2h[/tex]
Both the radius and height are effecting the volume. So before you can find dh/dt you need to find a way to relate r in terms of h.
HallsofIvy
43,021
970
Draw a triangle, vertex at the bottom, base horizontal, with height 6 and base length 10, representing the water tank. Draw a horizontal line representing the water line in the tank, with length 2r (since the diameter is twice the radius) and height above the vertex h. Use "similar triangles" to connect h and r.
Suggested for: Rate of change problem
  • Last Post
  • Last Post
