Homework Help: Rate of Change Question
  1. Dec 4, 2017 #1
    A building has an external elevator. The elevator is rising at a constant rate of ##2 \; \text{ms}^{-1}##.
    Sarah is stationary, watching the elevator from a point 30m away from the base of the elevator shaft.
    Let the angle of elevation of the elevator floor from Sarah's eye level be ##\theta##.
    Find the rate at which the angle of elevation is increasing when the elevator floor is 20m above Sarah’s eye level.
    2. Relevant equations
    3. The attempt at a solution
    Am I trying to find ##\frac{d\theta}{dt} = \frac{d\theta}{dh}\times \frac{dh}{dt}##. We know ##\frac{dh}{dt} = 2##. Am I on the right track???
  3. Dec 4, 2017 #2
    Ray Vickson
    Why not just keep going and see what you get?
  4. Dec 4, 2017 #3
    Ok then. ##h = 30 \tan{(\theta)}## so ##\frac{dh}{d\theta} = 30\sec^2{(\theta)}##. Hence, ##\frac{d\theta}{dt} = \frac{\cos^2{(\theta)}}{15}##.
  5. Dec 4, 2017 #4
    Dick
    Fine so far. But you should be able to express ##\frac{d\theta}{dt}## as a numerical value. What is ##\cos(\theta)## when ##h=20##?
  6. Dec 4, 2017 #5
    Ray Vickson
    Good. That is exactly what I was hoping you would do.
    I was basically encouraging you to do more on your own, by taking a chance and trying out something---win or lose. That is how we all learned.
  7. Dec 5, 2017 #6
    Thanks for all your help.
    I found the length of the hypotenuse then calculated ##\theta = \cos^{-1}\left(\frac{30}{\sqrt{1300}}\right)## then threw that solution into ##\frac{d\theta}{dt}##.
  8. Dec 6, 2017 #7
    Dick
    Right. Though you actually didn't need to find ##\theta##, right? All you need is ##\cos(\theta)=\frac{30}{\sqrt{1300}}##.
Have something to add?
Draft saved Draft deleted
Loading...
Similar Threads for Rate Change Question Date
Question on rates of change problem Jul 26, 2013
Rate of change question Mar 17, 2013
Rate of change questions Jan 31, 2013
Question about rate of change Feb 5, 2012
Rates of change question Oct 29, 2011
