Rate of change questions
  1. Jan 31, 2013 #1
    A ball is thrown vertically upwards and its height after t s is s m where
    s= 25.2t - 4.9t2
    Find the distance moved in the 3rd second
    2. At the instant from which time is measured a particle is passing through O and travelling towards A along the straight line OA. It is s m from O after t s where
    s= t(t-2)2
    What is the particle's greatest displacement from O, and how far does it move, during the first 2 s?
    3. The attempt at a solution
    1. 25.2(3)-4.9(9) = 31.5m
    Is the answer not 31.5m? But my book has a different answer.
    2. For the greatest displacement I believe it is (32/27)m
    but for the displacement after the first 2 seconds I'm not sure, cause if I put it in the formula for s I'll get 0.
    Help is greatly appreciated.
  3. Jan 31, 2013 #2
    1. What answer does your book have? The third second sounds like it could mean between t=2 and t=3, in which case the answer would be s3 - s2.
    2. Greatest displacement should be the point where the particle stops and turns around, in other words, the point where the speed is 0, which should be 32/27. For the second part, I believe it is asking the overall distance travelled by the particle, not the net displacement (e.g. if you run around a 400m track, you will have run 400m but your net displacement will be 0 since you are at the same position you started at).
    To find total distance travelled, find the critical points of your velocity (where s' = 0), plug t into s for each point, and take the sum of the differences between every two points. In other words:
    Distance = (Distance b/w points 0 & 1) + (Distance b/w points 1 & 2) + ... + (Distance b/w points n-1 & n)
    Distance = |S1 - S0| + |S2 - S1|
  4. Jan 31, 2013 #3
    for 1 the answer is 2.5m
  5. Jan 31, 2013 #4
    Ray Vickson
    1) Your 31.5 m is the displacement at t = 3, not the distance moved between times t=2 and t=3.
    2) Yes, s(2) = 0, but the particle travels out and back, so has travelled a finite, nonzero distance.
    BTW: in 2), there is no greatest displacement from zero, since s(t) → ∞ as t → ∞. Perhaps the question put an upper bound on t?
  6. Jan 31, 2013 #5
    No there's no upper bound that's all of the preamble to the question.
  7. Jan 31, 2013 #6
    Okay. Yes, #1 wants the distance traveled from t=2 to t=3. The net displacement is .7m, but there is a critical point between 2 and 3 where s' = 0. As per my above post, first find the critical point and then add the absolute values of the distance traveled before and after the critical point.
  8. Jan 31, 2013 #7
    I'm sorry I don't fully understand between the 2nd and 3rd second there's a point when displacement is 0? I should find that and then add to the .7?
  9. Jan 31, 2013 #8
    No, there's a point where the velocity, s' (ds/dt), is zero. This is a critical point where velocity changes sign and the ball turns around (when the ball reaches its highest point and starts falling back towards earth). Plugging in t doesn't tell you how far the ball has traveled, it only tells you where the ball is at that point in time. To find out how far the ball actually traveled, you have to add up the distances that the ball traveled between the boundary and critical points.
    |distance 1| + |distance 2| where distance 1 = scritical point - s2 and distance 2 = s3 - scritical point
  10. Jan 31, 2013 #9
    So the I subtract the the values of s for when t=3 and t=2
    I got from the max height(32.4m)
    32.4-31.5(t=3) = 0.9 and 32.4-30.8(t=2)= 1.6
    and then add them and that's the distance travelled 2.5m?
    All of this makes the 3rd second? Hm..
Similar Threads - Rate change questions Date
Rate of Change Question Dec 4, 2017
Question on rates of change problem Jul 26, 2013
Rate of change question Mar 17, 2013
Question about rate of change Feb 5, 2012
Rates of change question Oct 29, 2011
