Rate of Change for the area of the circle
In summary, the radius of a circle is decreasing at a constant rate of 0.1 centimeter per second. In terms of the circumference C, the rate of change of the area of the circle is -(0.1)C square centimeters per second.
Johny 5
35
The radius of a circle is decreasing at a constant rate of 0.1 centimeter per second. In terms of the circumference C, what is the rate of change of the area of the circle, in square centimeters per second?
A. -(0.2)piC
B. -(0.1)C
C. - {(0.1)C}/(2pi)
D (0.1)^2C
E. (0.1)^2piC
EDIT: i changed answer b from -(0.2)C to -(0.1)C i wrote it wrong.
EDIT: i changed the decreasing at a constant rate of 0.2 to 0.1.
I'm not going to answer your question right off the bat, because then you wouldn't learn anything. This is almost identical to the previous question you asked. Here is a starter:
[tex] \frac{dA}{dt} = \frac{dA}{dr} \frac{dr}{dt} [/tex]
dr/dt = -0.2
You can do the rest yourself.
im guessing dr/dt is not -0.2 instead its -0.1
so:
dA/dt = dA/dr * dr/dt
dA/dt = dA/dr * -(0.1)
C = 2(pi)r
r = C/2pi
dA/dt = C/2pi * -(0.1)
dA/dt = - {(0.1)C/2pi} ?
so its C?
Looks good to me, you can clean it up by writing it as [tex] -\frac{C}{20 \pi} [/tex]
See? You did it entirely yourself.
thanks you thnk i could ask another question within' the same topic because i don't think i should start another topic..
1. The problem statement, all variables and given/known
if d/dx{f(x)} = g(x) and if h(x) = x^2, then d/dx{f(hx))}2. Homework Equations
3. The Attempt at a Solution
f'(x) = g(x)
d/dx [f(h(x))] = g(h(x))
h(x) = x^2
so is this correct?
d/dx [f(h(x))] = [f'(h(x))] (h'(x)) = g(x^2)(2x) = 2xg(x^2)
No that is not correct.
Use the chain rule again, [tex] \frac{d}{dx}[f(h(x))] = f'[h(x)] h'(x) [/tex]
yea i edited my post after reading that in my book :p thanks :)
so:
C = 2(pi)r
r = C/2pi
so its C?
i think we made a mistake because we took out 2pi that was on the top...
so the answer should be
dA/dt = 2piC/2pi * -(0.1)
dA/dt = -(0.1)C
which is option B
can anyone comfirm this?...
i had a simular problem that r = 10 and i left 2pi on the top so I am assuming i have to leave 2pi on top for this instance too...
Yes. I have no idea how I missed that. You're right.
The reasoning behind it is that dr/dt = -0.1, dA/dr = 2pi*r
somehow I didn't pick up that you let dA/dr = C/2pi
thus making your dA/dt = C/2pi * -0.1
Obviously it should be 2pi*r*-0.1 which of course is -0.1C
How clumsy of me.
1. What is the formula for calculating the rate of change for the area of a circle?
The formula for calculating the rate of change for the area of a circle is 2πr, where r is the radius of the circle.
2. What does the rate of change for the area of a circle represent?
The rate of change for the area of a circle represents how quickly the area of the circle is changing with respect to the change in its radius. It is a measure of the slope of the area vs. radius graph.
3. How does the rate of change for the area of a circle relate to the circumference?
The rate of change for the area of a circle is related to the circumference through the formula 2πr, where r is the radius of the circle. This is because the circumference is equal to the rate of change of the area with respect to the radius.
4. How does the rate of change for the area of a circle change as the radius increases?
As the radius increases, the rate of change for the area of a circle also increases. This can be seen in the formula 2πr, where the value of r directly affects the rate of change.
5. Can the rate of change for the area of a circle be negative?
No, the rate of change for the area of a circle cannot be negative. This is because the area of a circle is always positive and increasing the radius will always result in an increase in the area, meaning the rate of change will always be positive.
