• Support PF! Buy your school textbooks, materials and every day products Here!
Ratio of potentials and charges on two spheres
  • Thread starter Sterfrye36
1. Homework Statement
Consider two "solid" conducting spheres with radii r1= 4 and r2= 1. I.E., r2/r1= 1/4.
The two spheres are separated by a large distance so that the field and the potential at the surface of sphere #1 only depends on the charge on #1 and the corresponding quantities on #2 only depend on the charge on #2.
Place an equal amount of charge on both spheres, q1=q2=Q.
After electrostatic equilibrium on each sphere has been established, what is the ratio of the two potentials V2/V1 at the "centers" of the two solid conducting spheres?
What is the ratio of the electric fields E2/E1 at the "surfaces" of the two spheres?
2. Homework Equations
As near as I can figure out:
q= charge
r= Displacement from the reference point in the direction of the field
Delta V= Kc (q/r)
E= Magnitude of the electric field
d= Displacement
Delta V= -E Delta d
3. The Attempt at a Solution
At first, I set the charge on each at 10 for the sake of convenience, than ran the numbers through the formula. I ended up with V1= 2.2475e10 and V2=8.99e10. When V2 was divided by V1, I ended up with a ratio of 4.
As far as electric fields went, I ran the second formula and then divided E2 by E1 for a ratio of 16.
Did I work this problem correctly?
Answers and Replies
Related Threads for: Ratio of potentials and charges on two spheres
  • Last Post
18K
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
9K
