- #36
EnumaElish
- 2,350
- 124
Computer science -- or any engineering or applied science dept., I guess. What are u sorry abt?
EnumaElish said:Computer science -- or any engineering or applied science dept., I guess. What are u sorry abt?
Hmph, I can't readily think of a counterexample to this. Closest I can get to a proof is, if you define [itex]\Delta_i = k_i - k_{i-1}[/itex] then it looks to me like one can select [itex]\varepsilon=\min\left\{\Delta_i\right\}_1^n[/itex] to get the result . All one needs is to select the minimum step size that would produce all elements of the subset, starting with k1.bomba923 said:... Can I rewrite the original statement more clearly as:
[tex] \forall \left\{ {k_1 ,k_2 , \ldots ,k_n } \right\} \subset \mathbb{Q}{\text{ where}}\;k_1 < k_2 < \ldots < k_n ,\;\exists \, \varepsilon > 0\;{\text{such that}}\;\forall n \in \mathbb{N}, [/tex]
[tex] \left\{ {k_1 ,k_2 , \ldots ,k_n } \right\} \subseteq k_1 + \varepsilon \left\{ {0,1,2, \ldots ,\left\lfloor {\frac{{k_n - k_1 }}{\varepsilon }} \right\rfloor } \right\} [/tex]
EnumaElish said:Hmph, I can't readily think of a counterexample to this. Closest I can get to a proof is, if you define [itex]\Delta_i = k_i - k_{i-1}[/itex] then it looks to me like one can select [itex]\varepsilon=\min\left\{\Delta_i\right\}_1^n[/itex] to get the result . All one needs is to select the minimum step size that would produce all elements of the subset, starting with k1.
*So basically, the greatest value of will be greatest common factor of all the elements in . I'll update later with a mathematical description of the previous sentence, from reading http://mathworld.wolfram.com/GreatestCommonDivisor.html . Later, I'll use this to develop a proof of the general statement,...unless you guys want to crack it!
