Ray Optics Question
Here is the problem I am working on:
Sunlight enters a room at an angle of theta = 32° above the horizontal and reflects from a small mirror lying flat on the floor. The reflected light forms a spot on a wall that is d = 1.9 m behind the mirror, as shown in Figure 26-42. If you now place a pencil under the edge of the mirror nearer the wall, tilting it upward by 5.0°, how much higher on the wall (delta y) is the spot?
Here is what I have done:
delta y = yf - yi = d tan thetaf - d tan thetai = (1.9m)(tan37 - tan32) = 24.45 cm
In WebAssign, I submitted both 24.45 cm and 24 cm, but neither was accepted. What am I doing wrong? My instructor said my answer is not close to that in WebAssign.
Answers and Replies
Doc Al
Mentor
45,137
1,438
You have the wrong angle. When the mirror's flat, the normal line to its surface points straight up. But when it's tilted, where does the normal line point? Now apply the law of reflection about that new normal.
George Jones
Staff Emeritus
1,148
Draw a separate diagram for the second situation, and put in the angles carefully.
Edit: Doc beat me to it.
When the mirror's tilted, the normal line points upward, away from the wall, right? So does this mean the angle I should replace is supposed to be 85 degrees?
OlderDan
3,021
When you tilt the mirror, the angle θ changes, so the reflection angle changes. But these angles are relative to the plane of the mirror, and the mirror is no longer flat on the table.
Okay, so I drew myself a picture. Originally the normal line is straight up, as Doc Al said. As the mirror is tilted 5 degrees, the normal line is now pointing 5 degrees in the upper left direction. Theta changes and increases to 37 degrees. But on the other side of the normal line, theta is 42 degrees, is that right? So I replace 37 with 42, or am I still doing something wrong?
OlderDan
3,021
I would give the angle on the right a name other than theta, since the angle you need to locate the spot is now theta + the 5 degree rotation, but yes, 42 degrees is the angle between the reflected beam and the floor.
Thank you!
Related Threads on Ray Optics Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
