RC Circuit, Charging, Question
In summary, the circuit is in series with a voltage source, two capacitors, and a resistor. The time constant is RC = 1.09 s, the initial potential difference across R is 5V, the current at t=3s is 6.37x10^-3 A, and the potential difference across C2 at t=3s is 4.68 V. To determine the voltage across C2, the equation V=Q/Ceq can be used, where Q is the total charge across both capacitors and Ceq is the equivalent capacitance of the two in series. The voltage across C2 can also be determined using a resistor divider method. In the other question, gneill will provide
letsgo
Consider the circuit below, where C1=80mF, C2=30mF, R=50ohms and E=5V.
At t=0, both capacitors are uncharged - so it's charging.
The circuit is in series, with E ---> C1 ---> C2 ---> R ---> (back to) E
a) Find the time constant.
b) The initial potential difference across R.
c) The current at t=3s.
d) The potential difference across C2, at t=3s.
C=Q/V
V=IR
X=Xmax(e^(-t/RC)) (where X is I, V or Q and is decreasing with time)
X=Xmax(1 - e(-t/RC)) (where X is I, V or Q and is increasing with time)
Here are my answers, can someone check if I'm right?
a)
time constant = RC = (50 ohms)(21.8 mF) = 1.09 s
b)
V=5.0 ohms (same as E)
c)
V=RI -> 5V=(50 ohms)I -> I=0.1 A
I=Imax(e-t/RC)
I=(0.1 A)[/SUB](e(-3s/1.09s))
I=6.37x10-3 A
d)
VCeq= Vmax(1-e-t/RC)
VCeq= (5 V)(1-e-3s/1.09s)
VCeq= 4.68 V
V=C/Q -> 4.68V=30mF/Q -> Q=6.4x10-3 C
τ(seconds) = resistance(ohms) * capacitance(Farads). Your result is a bit too big.
Nevermind,τ looks good.
So are the other answers good to?
b) I know you meant V not ohms
c) good
d) looking for a voltage across C2, VCeq is right though.
c) good
Thanks. And OK, you're right, I fixed it.
V=Q/Ceq
4.68=Q/21.8mF
Q=1.02 C, which is the same across each capacitor since they're in series.
And can you please, since you seem to know what you're talking about when it comes to RC circuits, answer this question of mine as well?
https://www.physicsforums.com/showthread.php?t=648367
for d) you need to determine the voltage across C2. It is done the same way as if you were going a resistor divider.
On your other question, gneill is on it (and will advise you well).
1. What is an RC circuit?
An RC circuit is a type of electrical circuit that consists of a resistor (R) and a capacitor (C) connected in series. It is commonly used in electronic devices for signal filtering, timing, and oscillation.
2. How does an RC circuit charge?
When a voltage source is connected to an RC circuit, the capacitor begins to charge. The capacitor charges up to the same voltage as the source, with the rate of charging depending on the values of the resistor and capacitor. As the capacitor charges, the voltage across it increases and the current decreases until it reaches its maximum charge.
3. What is the time constant of an RC circuit?
The time constant of an RC circuit is the time it takes for the capacitor to charge to 63.2% of its maximum charge. It is calculated by multiplying the resistance (R) in ohms by the capacitance (C) in farads (τ = RC).
4. How can I calculate the voltage across a capacitor in an RC circuit?
The voltage across a capacitor in an RC circuit can be calculated using the formula Vc = V0(1-e^(-t/τ)), where Vc is the voltage across the capacitor at a given time, V0 is the initial voltage across the capacitor, t is the time, and τ is the time constant.
5. What happens when an RC circuit reaches its steady state?
In an RC circuit, the steady state is reached when the capacitor is fully charged and there is no more current flowing through the circuit. At this point, the voltage across the capacitor is equal to the source voltage and the current is zero. The circuit remains in this steady state unless the voltage source or the circuit components are changed.
