Neutrinogun
- 9
Specifically #13 only.
Same image as above.
Loop equations
10 - 500,000* i1 - 500,000 * i2 - 500,000 * i3 = 0
10 - 500,000* i1 - q/ 5 * 10^-6 - 500,000 * i3 = 0
Junction equations
i1 = i2 + dq/dt
i1 = i3
Solving for i1 in the second loop equation, you get
i1 = 1 * 10^-5 - 0.2q
Substituting second junction and above i1 into the first loop equation, you get
i2 = 2 * 10^-5 - 2*10^-5 + .4q = .4q
Substituting into the first junction,
1*10^-5 - .6q - dq/dt = 0
Using the equation i = E/R * exp(-t/RC) to solve for time, I used
(2/3)(8) uA = (1*10^-5 / 1)(exp(-t/1.6667))
However, the correct answer is using 4 uA with the above equation. My main question is why do we use 4 uA as the current going through the capacitor instead of 16/3 uA. The overall resistance of the path through the switch would be 1,000,000Ω while the resistance of the capacitor path is 500,000Ω. Doesn't this mean that 2/3 of the current would flow through the capacitor, so 2/3 of 8 uA?
Thanks.
(PS. I realized afterwards that you don't need to use the current equation, but can use the given charge equation once you figure out the charge on the capacitors when 8 uA goes through the capacitors, which is 10 uC. However, I still think my way should work, or want to understand why it doesn't.)
