Homework Help: RC Circuit Problem
  1. Apr 18, 2014 #1
    [Mentor's note: this thread does not use the standard homework-help template because it originated in a non-homework forum. It was moved here instead of being deleted because it had already gotten significant help.]
    "A capacitor is being charged from a battery and through a resistor of 20 KOhms. It is observed the the voltage on the capacitor rises from 10% of its final value to 90%, in 15 seconds. Calculate the capacitor's capacitance."
    I know we are supposed to show an attempt at a solution, but I'm not even sure where to start with this one :/. I know I need to be able to find the time constant from the data given, and from there tau = RC, but I don't know how to incorporate the percentage difference. I just need a push in the right direction
  3. Apr 18, 2014 #2
    Simon Bridge
    Do you know any equations that show voltage as a function of time for charging a capacitor?
    (Check your course notes, or look online.)
    Call the max voltage V, and the initial time t.
    The initial voltage is V/10 at time t and the final voltage is 9V/10 at time t+15s
    Write down the equations for each of the times.
    What are the unknowns?
    You can also ask - what is the percentage change in voltage in time ##\Delta t= \tau##
    What is the percentage change in voltage in ##\Deta t = 15\text{s}##?
    How many times ##\tau## to get that percentage change?
  4. Apr 19, 2014 #3
    Simon Bridge
    Correction: that should be ##\Delta t = 15\text{s}##
  5. Apr 19, 2014 #4
    well, i know V(t) = V0 * e-t/RC
    so would my equations be:
    V(t) = (V/10) * et/RC
    V(t+15) = (9V/10) * e(t+15)/RC
    which leaves me two unknowns, V & C. sorry i don't really understand that last part, my notes are super confusing. ;x
  6. Apr 19, 2014 #5
    Simon Bridge
    Your equations have five unknowns: V(t), V(t+15), V, t, C.
    Also: look at the equation you used:
    As time increases, what happens to the voltage? (i.e. does it increase or decrease?)
    Now look at the problem description:
    In the problem, as time increases, what happens to the voltage?
    If your notes are too confusing for you - have a look online:
    http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
    http://www.electronics-tutorials.ws/rc/rc_1.html
    Take special care over what each variable means when you do the substitutions.
  7. Apr 19, 2014 #6
    well, as time increases, voltage on the capacitor increases and voltage on the battery decreases, so V decreases and V(t) increases
    if there are five unknowns i need more equations before i do substitutions right? what am i missing?
  8. Apr 19, 2014 #7
    Simon Bridge
    The voltage across the battery is always the same!
    The equation you used - was that for the voltage across the capacitor or something else?
    Which voltage does the problem want to know about?
    Thinking about the votage across the capacitor:
    Look at the equation you used:
    You used the wrong equation and you put the numbers in the wrong place in that equation.
    Please read the links I gave you.
  9. Apr 20, 2014 #8
    ok, voltage across capacitor:
    Vc = capacitor voltage
    Vs = voltage on battery
    initially:
    0.1 * Vc = Vs(1 - e-t/RC)
    0.9 * Vc = Vs(1 - e(-t+15)/RC)
    are these right??
    as time goes on, voltage on the capacitor is increasing
  10. Apr 20, 2014 #9
    Simon Bridge
    You have the right equation now: Vc=Vs(1-exp[-t/RC]) ... well done.
    - but still the wrong substitutions.
    At time t, Vc = ?
    At time t+15, Vc = ?
    (Vc is given as a percentage of another value - what is it in terms of the equation you are now using?)
  11. Apr 20, 2014 #10
    so its maximum voltage is the voltage of the battery?
    at time t, Vc = 0.1 * Vs
    at time t+15, Vc = 0.9 * Vs
    in which case Vs would cancel leaving something like 0.1 = 1-e-t/RC & 0.9 = 1-e(-t+15)/RC ?
    thanks so much for all this help btw, i really appreciate it
  12. Apr 20, 2014 #11
    Simon Bridge
    Now you are thinking.
    If you look at the equation Vc=Vs(1-exp(-t/RC)) - what value does Vc tend towards as t gets very big?
    There's your maximum value - you don't need me to tell you ;)
    So - you end up with two equations with two unknowns - just solve for the value you need.
  13. Apr 21, 2014 #12
    well as t gets bigger, e-t/RC goes to 0 i think .. so Vc does tend towards Vs? so my two equations are right? now i just substitute and solve?
  14. Apr 21, 2014 #13
    Simon Bridge
    If you are uncertain, you can always just put some numbers in and see.
    OR work it out
    note: exp[-t/RC] = e^(-t/RC) = 1/e^(t/RC) [the "exp[]" form is nicer to write down]
    so when t=10RC, 100RC, 1000RC
    ... what happens to exp[t/RC] ?
    ... what happens to 1/exp[t/RC] ?
    ... see? You don't need me to reassure you ;)
    Did you try it and see?
    You need to think of ways you can be more confident in your own work.
  15. Apr 22, 2014 #14
    thank you so much for all your help.
    one more quick question if i may, say i had the capacitor being discharged through a resistor, from 90% of it's max value to 10% in 20 seconds. i believe the formula i would use is Vc = Voe-t/RC. the steps would basically be identical i presume?
    0.9 * Vo = Voe-t/RC
    0.1 * Vo = Voe-(t + 20)/RC
    and just substitute and solve from there
  16. Apr 22, 2014 #15
    Simon Bridge
    Exactly.
    The underlying problem you have is "how can I know I have the right approach, without asking?"
    It is important for you to develop a set of skills and habits to deal with this issue, because, at some point, you will have to work on problems where nobody knows the right approach - so there is nobody to ask.
    One of the important habits is to "play" with mathematical relations - you could have checked out the last few questions by yourself just by plugging sample numbers into equations and watching what happens.
    A great tool for this is a computer graphing program of some kind.
    Then the computer can test your ideas numerically for thousands of sample numbers in less than a second. Very useful.
    Physics is not about knowing the right formulas - it's about understanding the relationships between phenomena. I, personally, have never memorized the formula for charging and discharging capacitors.
  17. Apr 22, 2014 #16
    yeah I know, i'm not usually this cautious. currently a comp. science major so most of my time goes there, and this question is part of an assignment that's rather important grade wise, wanted to be as sure as possible that i was doing the right stuff
    jus wanted to say thanks again you were such a huge help
  18. Apr 23, 2014 #17
    Simon Bridge
    No worries - enjoy.
Have something to add?
Draft saved Draft deleted
