How Does Current Flow in a Charging RC Circuit?
In summary, when an RC circuit is charging, the current does not flow across the plates of the capacitor, but an ammeter can detect a decaying current. The charge in the circuit remains neutral, with electrons moving from the positive plate to the negative plate. Under steady state, the capacitor behaves as an open switch and no current passes through the wires connected to it. However, if a resistor is connected in series with the capacitor, it initially behaves as a battery, but in steady state, it behaves as an open switch. In a circuit with a straight wire and a resistor, all the current will flow through the short wire, and no current will pass through the resistor due to Ohm's Law.
sArGe99
133
In an RC circuit under charging, does the current actually flow across the plates of a parallel plate capacitor?
Does charge emanate from both terminals of the battery and move to the plates of a capacitor or does charge only emanate from positive terminal and get stored in one of the plates and manage to polarize the other? How is it that both plates have equal magnitude of charge?
Under steady state, does no current pass through the wires connected to the capacitor even if a resistor is connected in series with it? In such case how do we find the current through the circuit,do we take into account the resistor connected in series with capacitor or just the other ones?
Just wanted to clear all errors in perception. Your help is appreciated.
No, but if you hook up an ammeter to the circuit, it will detect a decaying current as charges accumulate on the plates.
The entire circuit is neutrally charged and remains so at all times. As soon as you connect the capacitor, the positive terminal of the battery is at higher potential than the plate to which it is connected. The free electrons in the conductors will move from the positive plate, through the battery and onto the negative plate. When the positive plate plus connecting wire is at the same potential as the positive terminal, electrons stop flowing. The electrons on the negative plate leave an absence of electrons on the positive plate because the whole thing is neutral. That is why the charges o the plate are equal and opposite.
Remember these simple rules:
1. When an uncharged capacitor is suddenly connected to a battery, it initially (that means an infinitesimal amount of time after the connection) behaves as if it were a short (straight wire).
2. When a fully charged capacitor is suddenly connected to a resistor, it initially behaves as a battery of voltage Q/C.
3. A long time after a capacitor is connected to a circuit (steady state), it behaves as if it were an open switch.
By "behaves" I mean that, if one of the conditions as described above is met, you can replace the capacitor in the given circuit with a short or battery or open switch and analyze the new circuit instead as far as currents in resistors, etc. are concerned.
I have one more question.
If a resistor is connected parallel to a straight wire joining the two terminals of a battery, does any current pass through the resistor. Is there any current in the circuit?
A straight wire in a circuit diagram is, by convention, an equipotential line and has zero resistance. If such a wire (a short) is across a resistor, the two ends of the resistor will be at the same potential, therefore the potential difference across the resistor will be zero. According to Ohm's Law (V = IR), there will be no current through the resistor because V=0. All the current will flow through the short.
If there is no other resistor in the circuit, mathematically the current in the short will be infinite (I = emf/R) since the resistance of the short is zero. Physically there will be a very large current in the short because the short has a small but non-zero resistance. In that case either the short will vaporize or the battery will explode. That's why people often use fuses to protect circuits and current-limiting resistors to protect batteries.
1. What is an RC circuit?
An RC circuit is a circuit that contains a resistor (R) and a capacitor (C) connected in series. It is commonly used in electronic devices for filtering, signal processing, and timing applications.
2. How does an RC circuit work?
When a voltage is applied to an RC circuit, the capacitor charges up to the applied voltage through the resistor. As the capacitor charges, the voltage across it increases and the current decreases until the capacitor is fully charged. This charging process is exponential in nature and the time it takes for the capacitor to charge is determined by the values of the resistor and capacitor.
3. What is the time constant of an RC circuit?
The time constant of an RC circuit is a measure of how quickly the capacitor charges or discharges. It is calculated by multiplying the resistance (R) in ohms by the capacitance (C) in farads, and is represented by the symbol τ (tau). The time constant represents the amount of time it takes for the capacitor to charge to approximately 63.2% of the applied voltage.
4. What happens to the current in an RC circuit during charging?
During charging, the current in an RC circuit decreases as the capacitor charges up. This is because as the capacitor charges, the voltage across it increases and the difference between the applied voltage and the voltage across the capacitor decreases, leading to a decrease in current flow.
5. How can I calculate the voltage and current in an RC circuit during charging?
The voltage and current in an RC circuit during charging can be calculated using the equations V = V0(1-e^-t/RC) and I = I0e^-t/RC, where V is the voltage across the capacitor, V0 is the applied voltage, I is the current through the circuit, I0 is the initial current, t is time, R is the resistance, and C is the capacitance. These equations show the exponential nature of the charging process and can be used to plot the voltage and current over time.
