Re-ionization of DI water.
  • Thread starter Integral
Integral
Staff Emeritus
55
The tool I am working on needs a source of clean (cleaner then city water) water, ideally we would use distilled water, but what we have easy access to is a high grade DI water. Unfortunately our tool has stainless steel valves and tubing. It seems (as would be expected) the DI water is quickly rusting some of the steel parts. Is there a easy way to re ionize DI water without contaminating the upstream source? (The DI engineer would not be happy if we did that!)
Bystander
1,088
You can try passivating the stainless with hydrogen peroxide; be certain the apparatus is well vented if you use 10% or stronger, the decomposition is catalyzed by stainless and rapid enough to build up significant pressure.
Is the process sensitive to oxidation? Aerate the water before running it into the stainless. SS is stainless as a function of the oxide film on the surface. The passivation with peroxide, nitric acid, other solutions thickens that a bit, but if you can tolerate atmospheric oxygen, that's about all you need to maintain the "stainless" film. You might also examine the system for mixing of alloys.
Integral
Staff Emeritus
55
Thanks a lot, That is the kind of info I am looking for.
Related Threads for: Re-ionization of DI water.
  • Posted
10K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
