1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Real line integral
  1. May 29, 2010 #1
    Calculate the line integral [tex] \int\limits_{AB} x^2 dx+ \sqrt{xy}dy [/tex], where AB is a part of a circle in the first quarter of carthesian coordinates system ranging from A(0,R) to b(R,0).
    2. Relevant equations
    3. The attempt at a solution
    Parametrisation of a circle:
    x=Rcos(t), y=Rsin(t)
    dx=-Rsin(t)dt, dy=Rcos(t)dt
    t ranges from [tex]\frac{\pi}{2}[/tex] to 0.
    And so the integral with the parametrisation applied is:
    [tex]\int\limits_{\frac{\pi}{2}}^0( -R^3 cos^2(t) sin(t)+R^2 \sqrt{sin(t)cos(t)}cos(t))dt [/tex]
    Now, the first part of the sum is simple. The latter one, the one with the root, is, according to Mathematica, analytically uncalculable (returns hypergeometric function). Now, when I tried evaluating the definite integral (using Mathematica), it returned [tex]\frac{1}{24} \left(8 R^2-3 \sqrt{2} \pi R \sqrt{R}\right) [/tex], whereas the answer says it's [tex] \frac{1}{15} R^2 (6 \sqrt{R}-5R) [/tex]. Who's right and is it possible to calculate it on paper. Maybe I shuldn't have used the polar coordinates? But I would then end up with a double root!
  3. May 29, 2010 #2
    vela
    Staff Emeritus
    Education Advisor
    Are you sure the original integral is correct? I don't see how you can get a [tex]\sqrt{R}[/tex] in the answer from the integral you started with.
    EDIT: I think the integral is supposed to be
    [tex]\int_{AB} (x^2\,dx + \sqrt{x}y\,dy)[/tex]
    That'll give the answer you're trying to get, I think.
  4. May 29, 2010 #3
    That's what I was calculating, I just forgot to write the brackets ;). I wrote it correctly in 3-attempt at a solution. And this is what I evaluated in Mathematica. And integrating this root is the only problem :).
  5. May 29, 2010 #4
    Dick
    Did you notice vela's version of the integral is sqrt(x)*y*dy, not sqrt(xy)*dy?
  6. May 29, 2010 #5
    My bad, I didn't, sorry. But what it says in the exercise book is sqrt(xy). And the answer came from mathematica, it seems quite wierd to me as well, but i checked it a couple of times
    E: you're right, there is not root of r in the answer, my apologies. But the integral should be the way i wrote it.
  7. May 29, 2010 #6
    Mathematica returns:
    [tex]
    \int\limits_{AB} x^2 dx+ \sqrt{xy}dy =
    \frac{1}{24} \left(8 R^3-3 \sqrt{2} \pi R \sqrt{R}\right) [/tex]
    and is consistent with the numerical results.
  8. May 29, 2010 #7
    Whatever the result is, given that this exercise was taken from exercise book i would expect it to be calculable on a paper. And it is a book for undergraduates. WTF??
  9. May 29, 2010 #8
    vela
    Staff Emeritus
    Education Advisor
    Could you show us what you entered into Mathematica to get that result? In the second term, [tex]\sqrt{xy}[/tex] is proportional to R as is dy, so that term should be proportional to R2.
  10. May 29, 2010 #9
    Integrate[
    Sqrt[r^2*Sin[t]*Cos[t]]*Cos[t] - r^2*Sin[t]*(Cos[t])^2, {t, \[Pi]/2,
    0}]
    You are right, I was wrong. I messed up with those 'r's'. But nevertheless, question remains actual-how the hell am i supposed to calculate it on a paper with the knowledge i've got after first term??
  11. May 29, 2010 #10
    vela
    Staff Emeritus
    Education Advisor
    I was actually curious to see what jackmell did since you two got the same result in Mathematica, even though you had changed your answer a few hours earlier.
    I think it's just a typo in your book. To get their answer, you need to integrate [tex]\sqrt{x}y[/tex] instead of [tex]\sqrt{xy}[/tex], and you can do that easily with a substitution.
  12. May 29, 2010 #11
    Sorry about that. It's r^2:
    Code (Text):
    Clear[r]
    myval = Integrate[(-r^3)*Cos[t]^2*
         Sin[t] + r^2*Sqrt[Cos[t]*Sin[t]]*
         Cos[t], {t, Pi/2, 0}]
    [tex]
    \frac{1}{24} \left(8 R^3-3 \sqrt{2} \pi R^2 \right)
    [/tex]
    and that is consistent with the numerical results:
    Code (Text):
    In[28]:=
    N[(1/24)*r^2*(-3*Sqrt[2]*Pi + 8*r) /.
       r -> 5]
    r = 5;
    NIntegrate[(-r^3)*Cos[t]^2*Sin[t] +
       r^2*Sqrt[Cos[t]*Sin[t]]*Cos[t],
      {t, Pi/2, 0}]
    Out[28]=
    27.78265748492177
    Out[30]=
    27.78265752218859
  13. May 30, 2010 #12
    Well, you mey be right, but on the other hand, a couple pages earlier, in a chapter about double integrals (volume, area etc.) they expect you to integrate
    [tex]z=sin(\pi x y)[/tex]. After first integrating, let's say over y, you get [tex]\frac{cos(\pi x y)}{\pi x}[/tex], which again is imposiible to integrate in the meaning of finding an antiderivative. However, mathematica returns the same answer that thay gave in the book.
Similar Discussions: Real line integral
  1. Line Integral (Replies: 4)
  2. Line Integrals (Replies: 4)
  3. Line Integrals (Replies: 4)
Loading...
