Why is Power Dissipation Divided by Two in AC Circuits?
  • Thread starter amitjakob
  • Tags
    Ac Power
In summary: When looking at the impedance graph for a capacitor and inductor, what do you notice? Don't they oppose each other? This means...?Yes, they oppose each other. Additionally, when looking at the impedance graph, you'll notice that the resistance decreases as you move away from the center of the graph. This is because the inductor has a higher reactance than the capacitor.
amitjakob
hello all
just studying to that crazy electrical engineering 2 exam coming up friday
encountered something weird about power dissipation.
Given is an AC circuit, source of 10V f=100Hz Z=20 Ohm
Matched to give maximum power is the load impedance which will be 20 Ohm as well.
now my problem:
I have assumed to calculate the current (10V/40 Ohm = 0.25A) and then easily apply I^2*V which gave 1.25W now, in the answer sheet is given solution just half of it : 625mW
now ... why did they divide it by two? how should I know when to do that ? is that a different method I should apply for DC / AC circuits ? does it make any difference that it is called impedance and not ressistance
Thank you all for you time people
Greets, Amit.
And one more thing later on...
Load of 20 Ohm is actually combined from R||(C+L)
where R=50Ohm C=159.15microF xL=omega*L=10Ohm --> L=pi/20 ?? (omega=200pi)
so, after the dissipated real power over the load has found 625mW , which i still don't know why. we've been asked to find the power over the resistor(50Ohm) which is parallel to the CL combinatioin and is found to be Zero
left me with my mouth open with no direction to start and guess this answer
any ideas ?
sorry for bothering, thanks for reading&answering
amitjakob said:
hello all
now my problem:
Greets, Amit.
I guess you're finding the power delivered to the load? It seems that 1.25W is is the product of IRMS and VRMS. But what if we want to find the power across the 20ohm impedance? Shouldn't it be IRMS2*20ohm? That gives 625mW.
any ideas ?
Well from the data you've listed, it seems that 100Hz is the resonant frequency for L and C i.e. both the inductor and capacitor have the same reactance (10ohms). When you look at the impedance graph for a capacitor and inductor, what do you notice? Don't they oppose each other? This means...?
Thanx 4 the answers, ranger !
but still ... few points arnt so clear to me.
1. Irms: is that simply I/sqrt(2) or is it more complicated then that ? when do I use it, in all AC circuits ? in DC
do i use regular current or RMS as well ?
2. I would appreciate if you can put some more light or even link me
to more information about the second point where L&C oppose each
other and there fore no power is dissipated over the parallel resistor.
Thanks for the patience (-:
Correct. To get the rms current/voltage, just divide by sqrt(2).
This translates to:
v(t) = 10*sin wt
Given the frequency, one can find omega. The form which its stated above is small signal variation (AC). Here, 10 represents the maximum voltage (peak). It should be obvious why dividing by sqrt(2) gives RMS.
Let me ask you something, of what use is it to use RMS (effective) power as opposed to simply using peak?
Umm...I can't find a decent link with graph, but how would you express the impedance of both a capacitor and inductor in polar notation (no need to use specific values for Xl and Xc)?
well AC means alternating current and DC means direct current. AC changes with time sin wave. thus has frequency while DC is nonfluctuating current and is straight line graph parallel to axis.
Thus when we calculate problems in AC circuits we use rms values called root mean square value as current changes with time (current changes its direction) thus we take average current value to calculate the power same way we use rms values of voltage and thus power=Irms*Vrms/2.
While in DC the current does not change its value and thus we straight way use I value given to us and not rms values.
This translates to:
v(t) = 10*sin wt
Hey !
well ... i thinki understand the part where they cancel each other out, but i wonder how and why does it influencing the power on R making it zero
to make it easier i attached the original exam, from it is the first problem
tnx
  • ise_fee2_h04_sol.pdf
amitjakob said:
Hey !
tnx
Well if the C and L cancel out each other, then that makes the impedance on the branch which consists L and C...?
0 ... which means all current going through that branch and not through the resistor ?
Ahhh... i think i can flood this forums now and make its members busy for so long, as long as I am still studying for exam. sun is shining outside, everybody going to swim in the lake ... and I am here.
well at least not alone, huh ?
i meant these forums and not this forums ... too tired to spell, heheh...
You can think of it that way. Or you can say since the resistor (R2) is in parallel with 0ohm (a idealized piece of wire), the equivalent impedance is 0ohms. Therefore all the power is dropped across the potentiometer (R1) and the internal source resistance. Since we wish to get maximum transfer of power from source to load, the load should have a resistance equal to that of the source (which you already pointed out). Since this value is 20ohms, it should now be obvious why it seemed like they divided the total power by two.
Quick problem
From problem no1 in the file attached here.
1e) Which capacitance to make the apparent power real.
My direction was to try and make the Total impedance real, which would make
the Current real (voltage is real).
but I am kinda stuck, not able to proof in this way, I am pretty sure its an 'kinda-easy-if-you-get-the-hang-of-it' question ... but, i guess i didnt
any ideas ?
  • i2_f05.pdf
any ideas ?
Interesting problem. Are you aware of the following:
[tex]S = P + jQ[/tex]
where S is apparent power, P is real power and Q is reactive power.
So you are trying to make S = P right? You can read this for more help on the issue:
http://www.ibiblio.org/obp/electricCircuits/AC/AC_11.html
Thanks for the link, it looks interesting, just started to read
one thing bothered me there
They relate to amplitude of V or I as RMS, just as it is and without dividing
it by sqrt(2)for example, at the explanation coming directly after the RL series circuit
they say its a source of 120V RMS ... or does that mean it actually has the following formula v(t)=120*sqrt(2)*cos(wt+a)
or am i just competly mixed ... hopefully reading on will clear some stuff.
The highlighted section implies that you are indicating a time varying signal - not RMS! That 120V volt in that expression is the peak.
When we work with AC circuits, and we need to work with ohms law, power law, voltage divider, etc, we must use complex notation. A majority of these require use to divide and multiply quantities. You should know that polar notation is best suited for this. And of course the magnitude in polar notation is always RMS.
EDIT: sorry. I missed when you multiplied 120V*sqrt(2). In that case, its in peak. And it fits in properly to express small signal variations. So you're correct.
Very intereseting article, so much that i would never get from
my sleepy self-bored-to-death professor.
Anyways, too much already over 10 hours today
so i'll retire for now, see you tomrrow (for sure! hehehe...)
Night
1. What is real power in an AC circuit?
Real power in an AC circuit refers to the actual amount of power that is being consumed or dissipated by the circuit. It is measured in watts and is the combination of both active power and reactive power.
2. How is real power different from reactive power?
Reactive power is the power that is stored and released by inductive and capacitive elements in the circuit. It is measured in volt-amperes reactive (VAR) and does not contribute to the actual work done by the circuit. Real power, on the other hand, is the power that is actually used to perform work and is measured in watts.
3. Why is real power important in AC circuits?
Real power is important in AC circuits because it represents the actual energy that is being consumed and used. This is the power that is used by appliances and devices to function, and ultimately determines the efficiency of the circuit.
4. How is real power calculated in an AC circuit?
Real power can be calculated by multiplying the voltage and current in the circuit, and then multiplying that by the power factor (cosine of the phase angle between voltage and current). The formula for real power is P = V * I * cos(θ).
5. What factors can affect the real power in an AC circuit?
The real power in an AC circuit can be affected by factors such as the resistance and impedance of the circuit, the power factor, and the presence of inductive or capacitive elements. Changes in these factors can cause fluctuations in the real power consumed by the circuit.
  • Electrical Engineering
  • Classical Physics
