A Realism from locality?
Demystifier
Insights Author
2018 Award
9,854
2,857
Well, that's of course not what we'd consider science. Then I can as well just stick to the observations themselves. A black box providing answers is not what we aim at in science. We want to reduce it to some (as few as possible) fundamental laws, which then however are indeed a "black box".
So, if I understood you correctly, you are against hidden variable theories not because they are not directly measurable (after all, the wave function is also not directly measurable), but because we have a simpler theory that makes the same measurable predictions even without the hidden variables. Am I right?
Fine, but then remind me why did you recently found Bohmian mechanics interesting in the realm of non-relativistic QM? How that fits into your general view of science?
vanhees71
Insights Author
4,615
There's indeed no need for HV's as long as none are observed ;-).
I liked the book by Dürr on Bohmian mechanics. For me it showed that within non-relativistic QT there's no problem with this kind of non-local deterministic theory, but for non-relativistic physics there's anyway no need for locality to begin with since instantaneous actions at a distance are no contradiction with the causality structure of Galilean spacetime.
Of course, I'm not converted to Bohmianism as long as there is no convincing relativistic version of it.
Fortunately it's not needed either for the very arguments I made before: There's a working description of quantum effects consistent with relativistic space-time structure, namely the standard microcausal relativistic QFT.
I'm also not at the bottom of understanding what Bricmont et al want to "prove". If their statement of locality is wrong, I don't understand how this is consistent with the microcausality constraint of relativistic QFT.
I think what's also often missing in all these discussions (including the ones running in the parallel thread on entanglement swaping a la Zeilinger et al) is that never the complete state of the entangled photons is considered. It's just written down the polarization part but not the momentum part, which is however important in the considerations of locality arguments. I think this deserves another FAQ/Insight article. Maybe then my point of view becomes clearer too.
ftr
539
37
Well, you should also read the rest of this Sect. 4 in Baez's FAQ :-).
Yes I know that the conclusion is locality, I am just pointing to the way it is reached through some element of non locality.
martinbn
350
What is claimed to be proven? The papers claim that nonlocality is proven, but they don't claim that violation of relativity is proven.
OK, so what am I missing then? Non-locality is proven, which means that locality is disproven. And the locality they start with is the EPR locality of relativity. So how is relativity not violated?
Demystifier
Insights Author
2018 Award
9,854
2,857
Well, it depends on what exactly one means by "relativity". See e.g. Sec. 2 of http://de.arxiv.org/abs/1002.3226 to see in what sense nonlocality can be compatible with relativity.
martinbn
350
I'll take a look, but I don't think that there should be any freedom of choice on what is meant by relativity. And if it is compatible with relativity, then why call it non-locality! Why not globality, or global correlationality or something less confusing.
544
326
I agree with most of what you say, but disagree with this. Determining numerical parameters from a deeper mathematical theory is certainly a form of science, even if in the past alot of time was wasted on doing this by physicists. Usually once such an explanation is found it tends to constitute a complete revolution in mathematics - e.g. an extended theory of analysis - which is capable of turning existing physical theory upside down if the physicists realize that this is possible.
The problem is that the realization that some new idea constitutes fundamental progress - e.g. the mathematical necessity of non-locality for physics, which will probably require the invention of a new form of mathematics in tandem in order to describe it - usually through some novel form of unification of concepts, occurs at a vastly different rate in physics compared to in mathematics.
Another problem is that many different factions of physicists in different subfields spontaneously arise which each take the same validated mathematical methods (e.g. perturbative methods) as well as their own personally preferred underlying model far too seriously, such that the field of physics as a whole has become terribly fractured and horrible at effectively communicating about most partial actual new results.
Demystifier
Insights Author
2018 Award
9,854
2,857
But I explained it to you like 1000 times. The nonlocality is the property of the (hypothetic) more fundamental variables, called also "hidden variables". Those more fundamental variables are not described by relativistic QFT, so they do not need to obey the microcausality constraint of relativistic QFT.
A possibly useful analogy is thermodynamics vs atomic physics. Thermodynamics obeys the second law (the entropy increase law), but the more fundamental theory of atoms does not need to obey the second law. Just as there is no contradiction in the fact that the second law can emerge from a more fundamental theory which does not obey the second law, likewise there is no contradiction in the possibility that microcausality constraint can emerge from a more fundamental theory which does not obey the microcausality constraint.
Demystifier
Insights Author
2018 Award
9,854
2,857
For me, that's like saying that Boltzmann had no need to introduce his theory of atoms as a statistical explanation of thermodynamics.
Demystifier
Insights Author
2018 Award
9,854
2,857
Does it mean that you would be converted to Bohmianism if a relativistic version existed? If so then why? Why would Bohmian version of relatvistic QFT, if existed, would be better then ordinary relativistic QFT?
Demystifier
Insights Author
2018 Award
9,854
2,857
It's in fact straightforward to add the momentum part, but it doesn't help to understand the issue of (non)locality. Usually only the polarization part is analyzed explicitly because only the polarization is measured in experiments that violate Bell-like inequalities.
A. Neumaier
Insights Author
6,254
2,366
The momentum part is trivial; just take for each particle's part the tensor product with a smeared momentum state. Up to a joint phase, these remain constant throughout, hence can be factored out.
vanhees71
Insights Author
4,615
Sure, writing it in the form of ##|\text{momentum part} \rangle \otimes |\text{polarization part} \rangle## it's (here for the singlet Bell state in the polarization part)
$$(|\vec{p}_1\rangle \otimes |\vec{p}_2 \rangle - |\vec{p}_2 \rangle \otimes |\vec{p}_1 \rangle) \otimes (|H \rangle \otimes |V \rangle -|V \rangle \otimes H \rangle).$$
For wave packets just integrate over the momenta with some ##L^2##-function weight (e.g., a Gaussian).
zonde
203
Entanglement is between particles not observables. The state you wrote is just meaningless as polarization part already includes momentum:
##|H\rangle_{\vec{p}_1}\otimes|V\rangle_{\vec{p}_2} -|V\rangle_{\vec{p}_1}\otimes|H\rangle_{\vec{p}_2}##
vanhees71
Insights Author
4,615
Entanglement is a property of states.
What I wrote down is
$$|\vec{p}_1,H \rangle \otimes |\vec{p}_2,V \rangle - |\vec{p_1},V \rangle \otimes |\vec{p}_2,H \rangle - |\vec{p}_2,H \rangle \otimes |\vec{p}_1,V \rangle +|\vec{p}_2,V \rangle \otimes |\vec{p}_1,H \rangle
= [\hat{a}^{\dagger}(\vec{p}_1,H) \hat{a}^{\dagger}(\vec{p}_2,V) - \hat{a}^{\dagger}(\vec{p}_1,V) \hat{a}^{\dagger}(\vec{p}_2 H)] |\Omega \rangle.$$
The corresponding normalized state ket is given by this vector ##\times 1/2##.
It takes into account the Bose nature of photons. Your state is not symmetrized as a two-particle (two-photon) bosonic state should be.
25,267
6,400
I have no idea what you mean by this, since the polarization degrees of freedom are different from the momentum degrees of freedom; neither one can "include" the other.
It might be the case that the momentum and polarization degrees of freedom are entangled, but that is not the same as polarization "including" momentum.
zonde
203
Well, maybe "included" is not the right word. Polarization modes are indexed by spatial directions. In entaglement measurements interference happens between polarization modes in the same spatial direction. No interference is created between different spatial directions. That relationship between different spatial directions is revealed only indirectly by comparing outcomes of polarization mode interference measurements.
So it's all tied together. Two polarization modes and two spatial directions makes four combined modes that are measured pairwise and then compared.
vanhees71
Insights Author
4,615
I've no clue what you are talking about. Let's talk about two photons with momenta ##\vec{p}_1## and ##\vec{p}_2##. The natural complete one-photon basis is the momentum-helicity-eigenbasis ##|\vec{p},\lambda## where ##\vec{p} \in \mathbb{R}^3## and ##\lambda \in \{-1,1\}##. The helicity is the projection of the total angular momentum (sic!) to the direction of momentum.
A basis for the two-photon states are
$$|1_{\vec{p}_1,\lambda_1},1_{\vec{p}_2,\lambda_2} \rangle = \frac{1}{\sqrt{2}} \hat{a}^{\dagger}(\vec{p}_1,\lambda_1) \hat{a}^{\dagger}(\vec{p}_2,\lambda_2) |\Omega \rangle.$$
By definition these states describe non-entangled photons. Note however that these are not simply product states of single photons, but the creation operators automatically imply the symmetrization necessary to describe the photons as indistinguishable bosons.
A basis of maximally entangled two-photon states is given by
$$|\phi_{12}^{\pm} \rangle = \frac{1}{2} \left [\hat{a}^{\dagger}(\vec{p}_1,1) \hat{a}^{\dagger}(\vec{p}_2,1) \pm \hat{a}^{\dagger}(\vec{p}_1,-1) \hat{a}^{\dagger}(\vec{p}_2,-1) \right]$$
and
$$|\psi_{12}^{\pm} \rangle = \frac{1}{2} \left [\hat{a}^{\dagger}(\vec{p}_1,1) \hat{a}^{\dagger}(\vec{p}_2,-1) \pm \hat{a}^{\dagger}(\vec{p}_1,-1) \hat{a}^{\dagger}(\vec{p}_2,1) \right].$$
For details about entanglement of indistinguishable particles, see e.g.
J. C. Garrison, R. Y. Chiao, Quantum Optics, Oxford University Press (2008)
25,267
6,400
No, they aren't. I think you are confusing photon polarization with spin measurements on spin-1/2 particles like electrons. Both lead to the Hilbert space of a qubit for the relevant degrees of freedom, but the physical measurements are not the same.
zonde
203
Of course they are. Look here: Entangled photons, nonlocality and Bell inequalities in the undergraduate laboratory, page 2
Here spatial directions are called "idler" and "signal". If you have any doubts that "idler" and "signal" are spatial directions in page 3 you can read sentence:
"By placing polarizers rotated to angles ##\alpha## and ##\beta## in the signal and idler paths, respectively, we measure the polarization of the downconverted photons."
25,267
6,400
Yes, those are spatial directions, which are different degrees of freedom from the polarization degrees of freedom. Different polarization measurements are performed on the photons going in those two spatial directions, but that does not mean the polarization degrees of freedom are the same as the spatial direction degrees of freedom.
zonde
203
Of course polarization degrees of freedom and spatial direction degrees of freedom are different. There are both orthogonal polarization modes in each spatial direction for entangled state. And that's what goes into description of entangled state. There is ##|H_s\rangle## and there is ##|H_i\rangle##. So when someone writes entangled state omitting these subscripts, like: ##|\psi^+\rangle=\frac{1}{\sqrt{2}}(|H\rangle\otimes|V\rangle\ + |V\rangle\otimes|H\rangle)## different spatial directions are implied for the same polarization modes.
vanhees71
Insights Author
4,615
Well, this paper uses the usual simplification, treating the photons as if they were distinguishable. The correct polarization-singlet state, idealized as momentum eigenstates is
$$|\Psi^{-} \rangle = \frac{1}{2} [\hat{a}^{\dagger}(\vec{p}_1,H) \hat{a}^{\dagger}(\vec{p}_2,V) -\hat{a}^{\dagger}(\vec{p}_1,H) \hat{a}^{\dagger}(\vec{p}_2,V) ] |\Omega \rangle.$$
The location of the registration events of these photons comes in by placing the detectors at their locations and then what's well defined are the two-photon-detection and/or single-photon probabilities given by the expectation values of appropriate electric-field operators.
zonde
203
Does this "correct" state description produce the same predictions for entanglement measurements as the "incorrect" one?
Want to reply to this thread?
"Realism from locality?" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
