Really basic electronic question
  • Thread starter sameeralord
  • Tags
    Electronic
In summary, the concept of voltage is often mistaken for potential energy, but in reality, it is a measure of the potential difference between two points in an electric circuit. While the voltage may remain constant in a battery, the potential energy of electrons may decrease as they move through the circuit due to resistors and other components. The pressure analogy is often used to explain voltage to high school students, but it is important to understand that it is only an analogy and not the actual physical mechanism at work. The voltage difference between two points is what causes the movement of electrons in an electric circuit, not the other way around.
sameeralord
662
Hello guys :smile:
I got a small question with voltage and charge. If voltage provides potential energy for charges why doesn't the voltage decrease all the time when the charges are moving. I mean I only see voltage change when their are resistors and stuff but my question is shouldn't the voltage change all the time because the charges are losing potential energy as they are moving. Also can you explain potential difference to me. I'm bit confused with that. My electronic undertstanding is not really good and your help would be really appreciated
:smile: :smile: :smile: :smile: :smile: Thanks!
You are implicitly holding a picture in your head of a conga line of electrons zipping through the circuit. However, the drift speed is very small. What really happens is the electromagnetic wave passes through disturbing electrons in it's wake. The mean free path is small, they will not move all the way through the wire (they won't get that far at all) before they scatter and lose their energy to molecular collisions (which is why circuits lose so much energy to heat).
I think that you should think more about what the wave is doing and less what the electrons are doing.
Voltage is not potential energy. Charges do not gain voltage, nor do they lose voltage. Voltage is applied across a conductor in the same way that a pump creates pressure in a pipe. The electrons move as a result of this pressure.
Also, please note that real wires are not actually zero resistance, even though they are idealized in class. If you connect a wire across the terminals of a battery, a large current will flow, but the voltage will change smoothly from one end of the wire (1.5V, say) to the other (0V, say).
- Warren
Welcome to PF!
Hi sameeralord ! Welcome to PF! :smile: :smile: :smile: :smile: :smile:
A battery is usually an exact voltage.
The potential difference between the thingies of a 1.5 volt battery stays at 1.5 volts.
Think of it like water flowing out of a pipe in a tank.
If the tank is always full (because it is supplied from another tank), then the pressure at the pipe exit will be constant … and that's how batteries should behave.
But if the tank gradually empties, then the pressure will fall … but batteries aren't generally like that! :smile:
Though I suppose it depends on how the voltage is being produced … :confused:
erm … have I got that right, guys? :redface:
As you discharge a battery, its voltage will decrease. That's how the battery monitor on your cell phone knows when the battery is almost dead. Different battery chemistries have different profiles. Alkaline batteries being losing voltage from the time you begin using them, while lithium ion batteries often lose only very little voltage until they are almost completely depleted.
- Warren
This confused me a little bit...
- Warren
It starts by saying Voltage is not potential energy. But then it goes on to explain that voltage is like pressure in a pipe, which is potential energy. Now, voltage is often referred to as "electrical pressure," or "electrical potential." Please clarify; what do you mean by the statement that "Voltage is not potential energy"?
-Thanks
This really needs to be commented on. Voltage is electric potential difference. Electric potential is potential energy divided by charge. Voltage is a measure of potential energy, contrary to what you said.
Charges move because they are exposed to an electromagnetic force that accelerates them from rest. Not because they feel some kind of "pressure".
The fluids analogy is only an analogy and is not supposed to replace the correct explanation.
Thanks everyone who replied.:smile:. Thanks for the welcome as well. I like the pressure idea it makes it easier to understand. I was all this time thinking of potential energy turning into kinetic energy lol. Thanks once again for everyone who helped :cool:
No wait stop! You were right to think that, because it's true!
Batteries supply electric fields that accelerate electrons, that is they move to lower electric potential energy (and higher potential difference or voltage) transforming that energy into kinetic to conserve total energy. What you said is completely correct.
The pressure idea is only an analogy to use for high school students because the theory is too abstract for them to immediately grasp.
Well then I'm back where I started:smile:. Shouldn't the voltage change all the time then. I'm confused now
EDIT: Oh I reread your first post. It does makes sense. So then what does the resisotor. Does it decrease the current
No the voltage doesn't change all the time.
The change in the electric potential energy of an electron is due to the voltage difference of the battery, which does not change. They might be mathematically proportional to each other, but physically one causes the other but not the other way around.
It's the concept that you're confused about so let's step back and consider an electron in between a parallel plate capacitor instead--
You have two big sheets, one charged - and the other +. An electron in between the plates would be attracted towards the + sheet (and be repelled from the - sheet) and move towards the + sheet right? That is because of the electric force on the charge.
Now the electron accelerates because the electric field produced by the capacitor is doing work on it. So the potential energy of the electron changes with time. *BUT THE VOLTAGE DIFFERENCE ACROSS THE CAPACITOR REMAINS CONSTANT.* Why? The electric field the plates exert on the electron and thus the voltage difference had nothing to do with the electron.
And if the electron was not there, that electric field would still be there.
Voltage is strictly a spatial phenomenon. It is not a noun. There exists a point in space on one end of the battery at a potential of, say, 9V with respect to the other end of the battery. Again, this is a spatial phenomenon and is reduced when charge moves to equalize this potential. However, the chemicals inside a battery work to restore the original potential difference.
1. What is electricity?
Electricity is a form of energy caused by the movement of electrons through a conductive material. It can be harnessed and used to power various devices and systems.
2. What is a circuit?
A circuit is a closed loop or pathway through which electricity can flow. It typically includes a power source, such as a battery, and components such as wires, resistors, and capacitors.
3. What is the difference between AC and DC?
AC (alternating current) and DC (direct current) are two types of electricity. DC flows in only one direction, while AC alternates in direction. Most electronic devices use DC, while AC is used to transmit electricity over long distances.
4. What is a resistor and what does it do?
A resistor is an electronic component that resists the flow of electricity, causing a reduction in current and voltage. It is typically used to control the amount of electricity flowing through a circuit.
5. What is a transistor and how does it work?
A transistor is a semiconductor device that can amplify or switch electronic signals. It works by using a small amount of current to control a larger current, allowing for precise control of electronic circuits.
  • Electromagnetism
  • Electromagnetism
