Really basic stuff that I am confused on.
  • Thread starter Alex48674
  • Tags
    Confused
In summary, the conversation discusses the topic of simplifying equations with exponents and the importance of choosing the correct root. The speaker also mentions their interest in math and science and their frustration with a teacher who gives incorrect information. They also ask for clarification on the number of solutions for an equation involving exponents. The summary concludes with a request for help understanding mathematical symbols used in the conversation.
Alex48674
67
ok this is really basic stuff that seems obvious I can't do, but I want to know why (I'm an 9th grade alg. 2)
1=1^(4/4)=(+-1^(2))^(2/4)=(+-1^(2))^(1/2)=+-1^(2/2)=+-1 Why exactly doesn't this work,other then you get -1=1, but other then that in the process.
I have other questions along similar lines, but I don't have time to post them right now.
Thanks =]
Mathematics news on Phys.org
[tex]1=1^{4/4}=((\pm 1)^2)^{2/4}=((\pm 1)^2)^{1/2}=(\pm 1)^{2/2}= \pm 1 [/tex]Why exactly doesn't this work,other then you get -1=1, but other then that in the process.
Thanks =]
My best answer for you use is because you choose the wrong root of 1. There are two square roots of one. You equation only is valid for the positive square root.
Indeed. Suppose:
a2 = b2
or, a2 - b2 = 0
or (a - b)(a + b) = 0
thus, a = b or (-b)
In your case since "a" is positive, so is "b".
John Creighto said:
Another thing that is illegal is canceling out common factors from the numerator and denominator in the exponent. The reason being is if you have a number
x^(1/n) then there are n possible roots:
http://en.wikipedia.org/wiki/Root_of_unity
http://en.wikipedia.org/wiki/Nth_root
in General:
x^(1/n)=||x^(1/n)||exp(-i*2*pi/n)
Man that's why I'm all screwed up now, my teacher said you could. =\. I've stopped listening to her now =P Thanks for the reply. So just to clarify if you have x^(4/4), you can't cancel out the 4/4 too 1 or any variation of that, you have to work through it? Thanks, I've got a couple more things I'll put one up at a time.
is x^(n/m) = to (x^(1/m))^(n)
thanks for the replys
Most grade 9 students wouldn't get themselves into trouble by doing as the teacher said. I'm sure the exceptions, which you discovered will not show up in your homework questions. I'm impressed that you are taking an interest in this stuff at grade 9.
Haha thanks, I'm just curious about maths and science in general, it's something to think about. The problem is that the teacher really isn't very bright, and says wrong stuff all the time, and I took a couple of the things and extended them a bit, and now everything is a bit messed up ='[.
It's annoying when people make simplifications in stuff like maths and science, because everything you base from there on out is wrong.
Also I'm a bit annoyed, because last year my teacher wouldn't let me take alg II because of the high schools not liking it, so I'm a bit bored through most of it.
Also do any of you know what I could do to occupy my time in class, I've already finished reading most of the alg. II textbook while not paying attention lol =]
Also another one is is this right.
y=x^(1/2)
x^(2/4)= [(+-x)^(2)]^(1/4)= (+-x)^(1/2)=yi,-yi, y, -y
Is this right that this has 4 solutions? Or can I not cancel out the exponents. This is one of the extensions I've done from that.
Some one who's better at this correct me if I make a mistake.
If you want to be completely general, I'm not sure that x^(n/m) is well defined unless you put in some restrictions like restricting the roots to the positive roots.
Rather let's consider the following:
(x^n)^(1/m)=||x^n||exp(-i*2*k*pi/m)
(x^(1/m))^n=(||x||exp(-i*2*k*pi/m))^n
=||x||^n*exp(-i*2*k*pi*n/m)
=||x^n||*exp(-i*2*k*pi*n/m)
The first expression has m roots. The second expression will only have m roots if n and m share no common factors.
Right yea I forgot that. Variables can only be positive real number integers. What exactly does || || mean, I'm not sure if I write it some other way. And what is exp and abbreviation for? thanks, once I know what these stand for I will be able to work out yalls posts a bit better =]
y=x^(1/2)
It seems to work. In general you can't blindly cancel the exponents but when you wrote down the two for the inverse of x^2 you seem to be okay. You just must recognize that 2 of those roots need to be thrown away. So [(x)^(2)]^(1/4) has 4 roots but x^(1/2) has two roots.
Perhaps I should try to elaborate somewhat on the principle.
Complex numbers are numbs which in general have both a real and imaginary part written as:
z=x+i*y
where x is the real part and y is the imaginary part.
Complex numbers can be written in polar form:
z=||z||exp(-i angle(z))
where:
the magnitude of z is given by:
||z||=sqrt(x^2+y^2)
and the angle (argument) of z is given by:
angle(z)=arctan(x,y)
Complex numbers in polar form can be converted back to rectangular form by using eular's Identity.
[tex] exp(-i \theta )=cos( \theta )+i*sin( \theta )[/tex]
From
Really basic stuff that I am confused on._identity]Eular's identity[/url] is that complex numbers which phase (angle) differ by 2 pi are equal.
see: http://en.wikipedia.org/wiki/Radian
Returning back to polar form:
||z||exp(-i angle(z))=||z||exp(-i angle(z)+2*k*pi)
for any integer k
Therefore the Nth root of of z is given by:
z^(1/n)=||z||^(1/n)exp(-i angle(z)/n+2*k*pi/n)
Well, it can have multiple meanings. It is usually used to represent an idea of length. For real numbers length is the absolute value. That is we remove the sign of the number.
I notice that wikipedia uses |z| instead of ||z||.
http://en.wikipedia.org/wiki/Comple...forums.com/newreply.php?do=newreply&p=1616959
Physics Help and Math Help - Physics Forums - Reply to TopicAbsolute_value.2C_conjugation_and_distance
Anyway, If we think of a complex number as a vector then it it makes sense to use ||z|| for magnitude. That is viewing a the complex number z=x+iy as the vector (x,y) then the magnitude (x,y) is given by:
||z||=||(x,y)||=sqrt(x^2+y^2)
However, I presume that mathematicians wish to distinguish between complex numbers as vectors as you can have vectors of complex numbers so they use |z| instead of ||z|| because |z| is like absolute value, while ||z|| is usually used to represent length (norm).
So we can think of the absolute value of a complex number as removing the phase of a number just like the absolute value of a real number removes the sign of the number.
Do you wish to learn more mathematics? I think the easiest subjects for someone of your ability to learn would be Discrete mathematics, or linear Algebra. That advantage of learning these is you don't need to understand Calculus to learn them.
Linear Algebra is more useful but if your are just playing around with mathematics you might have more fun with discrete mathematics. You seem to have an interest in complex numbers but I don't know if it is advisable to study complex numbers before learning calculus. You might be able to learn set theory but while set theory is valuable for mathematics it is hard to see how to apply it without a certain level of mathematical maturity.
Ah alright i think I see, so let me see if this is right.
|x| where x is a real number is absolute value (magnitude)
||x|| for a real number is the vector, which is where you get the polar form notation from
|x| for an imaginary number is the vector
||x|| for an imaginary number is the magnitude.
is that about right? And so where does the exp come in?
Yea that is what i am really looking for, some mathematics that I can teach myself that I won't be learning through my regular courses in high school. So I just quickly wikipediad both, and the discrete one seems a bit more fun, like you said, as it has more to do with ideas. What maths should I be able to do to do these?
Thanks for all your help, I really appreciate it =]
correct. Although we can also used it for absolute value/magnitude of complex numbers.
Should say ||x|| stands for the magnitude (norm) of x. Usually when we say magnitude (size) we are talking about vectors.
No, we are still using the symbols for the ideas of absolute value or magnitude. Absolute value is usually used in the context of numbers while magnitude is used in the context of vectors. The reason the terms are somewhat interchangeable is that complex numbers are like vectors in the sense that they obey the same rules with regards to addition.
Complex numbers add as follows:
x1+i y1=(x1+x2) + i *(y1 + y2)
while vectors add as follows:
(x1,y1)+(x2,y2)=(x1+x2,y1+y2)
Vector addition could be thought of head to tail addition:
http://upload.wikimedia.org/wikipedia/commons/2/28/Vector_addition.svg
That is you can add vectors by translating one vect towards the other vector without changing the direction of the vector so that the head of one vector connects to the tail to the other. Then the resulting vector is the arrow which points from the tail of one vector to the head of the other vector:
I think that the people here are helpful enough that if you are patient you should be able to get though a discrete math book which is geared towards first or second year university students. I think your background is strong enough. You might struggle some with proofs at first as they will be new to you.
On another note. I bet the answers to your questions aren't as basic as you thought.
You're going to have to get use to simplifications all though high school and a lot of the way though university.
Cool, I'll start browsing for online discrete math books!
No, the answers really weren't lol, I'm going to have to reread everything tomorrow so i get it (it's 11 here, and I'm getting pretty tired, so I am going to have to stop here and do my homework and get some sleep)
Good, I tend to like proofs =]
I'll be back tomorrow, probably asking more questions haha, again thanks for your help =D
i don't exactly get what all this means or what you intend to do with it but i do know 1 is not equal to negative one. don't forget when you take the principle square root of a number the answer will be positive.
alex check out the mit online courseware.
sorry i didnt realize my post was so late and rather irrelevant to the current topic.
1. What is the scientific method and how is it used?
The scientific method is a systematic approach to answering questions or solving problems in a scientific way. It involves making observations, forming a hypothesis, conducting experiments, analyzing data, and drawing conclusions. This method is used by scientists to ensure that their research is objective, reproducible, and reliable.
2. What is the difference between a hypothesis and a theory?
A hypothesis is an educated guess or prediction based on observations and previous knowledge. It is a proposed explanation for a phenomenon that can be tested through experiments. A theory, on the other hand, is a well-established and extensively tested explanation for a natural phenomenon. It is supported by a large body of evidence and is accepted by the scientific community.
3. What are independent and dependent variables?
An independent variable is a factor that is manipulated or changed by the researcher in an experiment. It is the cause of the observed changes in the dependent variable. The dependent variable, on the other hand, is the factor that is measured or observed in response to the changes in the independent variable. It is the effect of the independent variable.
4. What is the difference between a control group and an experimental group?
A control group is a group in an experiment that is not exposed to the independent variable. It is used for comparison with the experimental group, which is the group that receives the independent variable. The control group allows scientists to determine the effect of the independent variable by providing a baseline for comparison.
5. How do scientists ensure the accuracy and reliability of their results?
Scientists use various methods to ensure the accuracy and reliability of their results. They carefully design experiments, control variables, use appropriate sample sizes, and replicate their experiments. They also use statistical analysis to analyze their data and determine the significance of their results. Peer review and replication by other scientists also help in verifying the accuracy and reliability of scientific findings.
  • General Math
  • General Math
  • General Math
