Homework Help: Really dumb question but
  1. May 9, 2012 #1
    Calculate the value of e.
    2. Relevant equations
    3. The attempt at a solution
    If I substitute n=infinity into that limit, wouldn't I get e = 1?
    (1 + 1/(infinity))^infinity
    As the denominator of 1/infinity approaches very large values, 1/infinity approaches zero.
    Therefore, (1 + 0)^infinity
    e = 1
  3. May 9, 2012 #2
    SammyS
    Staff Emeritus
    No, you won't get 1 .
    Try some successively larger values for n to see what happens !
  4. May 9, 2012 #3
    Ya, but I don't understand why.
  5. May 9, 2012 #4
    sharks
    Not so long ago, i did the same mistake as you did in post #1.
    Basically, you're trying to find the limit of: [itex]\lim_{n\to \infty}n^n[/itex]
    [tex]Let\; y=\left( 1+ \frac{1}{n} \right)^n[/tex] Hint: Take logs on both sides.
  6. May 9, 2012 #5
    Try writing out the polynomial for a given [itex]n[/itex]:
    [tex]s_n = \left(\frac{1}{n}\right)^n (1+n)...(1+n) = \left(\frac{1}{n}\right)^n (1 + a_1 n + a_2 n^2 + ... + a_{n-1} n^{n-1} + a_n n^n)
    [/tex]
    where the coefficients are simply those of Pascal's triangle. Obviously as [itex]n\rightarrow \infty[/itex], the former terms are small compared to the latter, so
    [tex]s_n \approx \frac{1}{n^n} ((n-1) n^{n-1} + n^n),[/tex]
    since the second to last term in a row of Pascal's triangle is always the number of the row minus one. Therefore
    [tex]s_n \approx \frac{1}{n^n} (2 n^n - n^{n-1}) = 2 - \frac{1}{n}[/tex]
    Obviously the latter term drops off as [itex]n[/itex] gets large, but the contribution it gave to the term of order [itex]n^0[/itex] sticks behind. Try it with keeping the contribution to that order with three terms, four, etc.
    Edit: And I don't think this is a dumb question. I had to come up with that reasoning when I just read your post. I suppose it serves to illuminate that sometimes our intuition about the behavior of large numbers can lead us astray!
  7. May 9, 2012 #6
    I took the log of both sides, and then I moved the n exponent to the coefficient, so I got:
    logy = nlog(1+1/n)
    But I'm not sure where to proceed from here.
    Wow. I'm totally lost. I didn't even understand the very first step you did.
    If I understand correctly, Pascal's triangle is:
    So where did you get [tex]s_n = \left(\frac{1}{n}\right)^n (1+n)...(1+n)[/tex] from?
  8. May 9, 2012 #7
    The first step I did is to pull out [itex]n^{-n}[/itex] from the polynomial, leaving [itex]s_n = n^{-n} (1+n)^n[/itex]. Pascal's triangle gives you the coefficients of that latter polynomial, whose lowest order term is surely 1 and whose highest order term is surely [itex]n^n[/itex].
  9. May 9, 2012 #8
    Mark44
    Staff: Mentor
    It's not legal to substitute ∞ into an expression and do arithmetic on it.
    This is one of several indeterminate forms, which include [0/0], [±∞/∞], [∞ - ∞], and [1]. These show up in the context of limits, and indicate that some more work needs to be done.
  10. May 9, 2012 #9
    y=(1+n^-1)n
    =n^-n(1+n)^n
    How did you go from the first step to the second step?
    What if I do:
    Let m = 1/n
    lim as m approaches 0 (1+m)^(1/m)
    = (1+0)^(1/0)
    = 1^(1/0)
  11. May 9, 2012 #10
    Mark44
    Staff: Mentor
    It's not legal to divide by zero, either.
  12. May 9, 2012 #11
    So how would you solve this limit without using the approximation method then?
  13. May 9, 2012 #12
    Mark44
    Staff: Mentor
    Continue with what you were doing earlier...
    log(y) should be ln(y).
    Rewrite the right side as [ln (1 + 1/n)]/(1/n).
    Take the limit of both sides. If necessary, use L'Hopital's Rule.
  14. May 9, 2012 #13
    I give up.
    I'm trying to learn L'Hopital's Rule. Learning Pascal's Triangle was already hard enough. :(
    edit: I'll keep trying, but this is going to take me some time.
  15. May 9, 2012 #14
    sharks
    L'Hopital's Rule isn't too complicated: here is the formal definition
    Basically, it relates to fractions and if you put the value of the limit in the numerator and denominator, and if you get 0/0 or ∞/∞, (which are called indeterminate forms) then you will need to use L'Hopital's Rule. The rule simply requires that you differentiate both the numerator and denominator, independently. In some cases, you'll need to repeat the procedure.
  16. May 9, 2012 #15
    I just noticed at the end of this: not only did I divide by zero, but I still get 1^infinity at the end, which is an indeterminate form. Opps!
    Back on track, okay, so I did that rule, but I still ended up with a value of 1! D=
    http://i2.lulzimg.com/4cb849a256.png [Broken]
    [tex]y\quad =\quad { (1+{ n }^{ -1 }) }^{ n }\\
    lny\quad =\quad { ln(1+{ n }^{ -1 }) }^{ n }\\
    lny\quad =\quad nln(1+{ n }^{ -1 })\\
    \underset { n\rightarrow \infty }{ lim } lny\quad =\quad \underset { n\rightarrow \infty }{ lim } \frac { ln(1+{ n }^{ -1 }) }{ { n }^{ -1 } } \\
    \underset { n\rightarrow \infty }{ lim } lny\quad =\quad \underset { n\rightarrow \infty }{ lim } \frac { \frac { 1 }{ 1+{ n }^{ -1 } } ({ -n }^{ -2 }) }{ { -n }^{ -2 } } \\
    \underset { n\rightarrow \infty }{ lim } lny\quad =\quad \underset { n\rightarrow \infty }{ lim } \frac { 1 }{ 1+{ n }^{ -1 } } \\
    \underset { n\rightarrow \infty }{ lim } lny\quad =\quad \frac { 1 }{ 1+{ \infty }^{ -1 } } \\
    \underset { n\rightarrow \infty }{ lim } lny\quad =\quad \frac { 1 }{ 1+0 }[/tex]
  17. May 9, 2012 #16
    sharks
    So, you've reached: [tex]\lim_{n\to \infty} \ln y = 1[/tex]
    But, [tex]\lim_{n\to \infty} \ln y = \ln \lim_{n\to \infty} y[/tex]
    Now, can you find [itex]\lim_{n\to \infty} y [/itex]?
  18. May 9, 2012 #17
    Mark44
    Staff: Mentor
    OK, since lim ln(y) = 1, then y = ?
  19. May 9, 2012 #18
    ln * lim(y) = 1
    lim(y) = e^1
    = e
    But I still haven't found a value. :|
  20. May 9, 2012 #19
    sharks
    Here, e, represents the exponential value. Use your calculator. What is the value of [itex]e^1[/itex]?
  21. May 9, 2012 #20
    The original question was:
    Essentially, what we did was:
    e = e
    = 2... (using the calculator function)
    But how did the calculator get that value?
  22. May 9, 2012 #21
    sharks
    According to my calculator, e = 2.718281828
    LOL! Sorry, i can't go into the electronics that pump out that number from your calculator. It happens due to logic gates. e has a standard value, much like [itex]\pi[/itex].
  23. May 9, 2012 #22
    How do mathematicians know what e is equal to?
    How did they calculate it?
    Did they just use very large values of n?
  24. May 9, 2012 #23
    sharks
    e = 1/0! + 1/1! + 1/2! + 1/3! + 1/4! + 1/5! + 1/6! + ....
  25. May 9, 2012 #24
    Alright. Thank you everyone for your time.
    I think I understand it now. I was surprised to find that 1^infinity is an indeterminate form! I thought it would just equal 1.
  26. May 9, 2012 #25
    sharks
