Really hard related reates problem
  • Thread starter iRaid
V=20 S=6 E=2 H=20/12 (from V=SEH?)
[itex]\frac{dS}{dt}=-.2[/itex] <--- + OR -?
[itex]\frac{dE}{dt}=.3[/itex] <--- + OR -?
V=SEH
Product rule for 3 variables:
[itex]\frac{dV}{dt}=SE\frac{dH}{dt}+EH\frac{dS}{dt}+SH \frac{dE}{dt}[/itex]
[itex]0=SE\frac{dH}{dt}+EH(-.2)+SH(.3)[/itex]
[itex]-EH(-.2)-SH(.3)=SE\frac{dH}{dt}[/itex]
[itex]\frac{-EH(-.2)-SH(.3)}{SE}=\frac{dH}{dt}[/itex]
[itex]\frac{-(2)(\frac{20}{12})(-.2)-(6)(\frac{20}{12})(.3)}{SE}=\frac{dH}{dt}[/itex]
[itex]\frac{-7}{36}=\frac{dH}{dt}[/itex]
Negative, therefore decreasing.
Answers and Replies
Dick
26,263
619
The method of solution is fine. But picture the problem a little more carefully. It tells you the side walls are moving together at .2 m/s. This doesn't tell you dS/dt=(-.2). What does it tell you?
It means that they're getting smaller, therefore negative right? so that's why dS/dt is negative and not dE/dt?
Dick
26,263
619
Does it mean that dS/dt=-.4? Not sure?
If the side walls are getting closer it's the end walls that are getting shorter, right?
OH I see, one sec let me retry this.
Ended up getting -1/12 = dH/dt is this correct? So therefore the depth of the liquid is decreasing.
Dick
26,263
619
Well, I got +1/12=dH/dt. One of us made a mistake.
Um I think I made the mistake because I said dS/dt is negative, should be positive since the sides are getting bigger and the ends are getting smaller... But I'm not positive..
Dick
26,263
619
What did you use for dS/dt and dE/dt?
dS/dt=-.3
dE/dt=+.2
Dick
26,263
619
dS/dt=-.3
dE/dt=+.2
Now that's not right, is it? If the side walls are getting closer the end walls are getting shorter. So dE/dt should be negative.
That's what I thought I did wrong, thanks for all your help.
Much appreciated.
Related Threads on Really hard related reates problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
