Can Shawyer's EmDrive Really Defy the Laws of Physics?
  • Thread starter scott1
In summary, this article discusses how a supposed "electromagnetic drive" of Roger Shawyer violates conservation of momentum. The article also discusses how relativity comes into play and how the device doesn't work - no matter what Shawyer says.
scott1
350
Realtivity drive:Is it really possible?
I saw this article:
The trip from London to Havant on the south coast of England is like traveling through time. I sit in an air-conditioned train, on tracks first laid 150 years ago, passing roads that were known to the Romans. At one point, I pick out a canal boat, queues of cars and the trail from a high-flying jet - the evolution of mechanised travel in a single glance.
http://www.newscientisttech.com/article/mg19125681.400;jsessionid=IOBCJLIGJBPC?DCMP=ILC-OpenHouse&nsref=mg19125681.400INT
and here's his paper:
http://www.newscientist.com/data/images/ns/av/shawyertheory.pdf
Does this reallty work?
http://golem.ph.utexas.edu/category/2006/09/a_plea_to_save_new_scientist.html#more
However, I really was gobsmacked by the level of scientific illiteracy
in the article “Fly by Light” in the 9 September 2006 issue,
concerning the supposed “electromagnetic drive” of Roger Shawyer. If
Shawyer’s claims have been accurately reported, they violate
conservation of momentum. This is not a contested matter; in its
modern, relativistic form it is accepted by every educated physicist
on the planet. The writer of this article, Justin Mullins, seems
aware that conservation of momentum is violated, but then churns out a
lot of meaningless double-talk about “reference frames” which he seems
to think demonstrates that relativity somehow comes to the rescue:
Hang on a minute, though. If the cavity is to move, it must be pushed by
something. A rocket engine, for example, is propelled by hot exhaust
gases pushing on the rear of the rocket. How can photons confined inside
a cavity make the cavity move? This is where relativity and the strange
nature of light come in. Since the microwave photons in the waveguide are
traveling close to the speed of light, any attempt to resolve the forces
they generate must take account of Einstein’s special theory of
relativity. This says that the microwaves move in their own frame of
reference. In other words they move independently of the cavity - as if
they are outside it. As a result, the microwaves themselves exert a push
on the cavity. Each photon that a magnetron fires into the cavity creates an equal and
opposite reaction - like the recoil force on a gun as it fires a bullet.
With Shawyer’s design, however, this force is minuscule compared with the
forces generated in the resonant cavity, because the photons reflect back
and forth up to 50,000 times. With each reflection, a reaction occurs
between the cavity and the photon, each operating in its own frame of
reference. This generates a tiny force, which for a powerful microwave
beam confined in the cavity adds up to produce a perceptible thrust on
the cavity itself.
An aside... If Shawyer is correct, however, and his theory proven true by repeatable experimentation then this is a breakthrough.
It is being discussed in Skepticism and Debunking. Its a hoax. From the diagram of the device, it is evident that the radiation pressure is greater at one end of the device than the other, but the force is the same (remember to add the force on the sides) and the net force is zero.
The device doesn't work - no matter what he says.
Ok lock this thread. I don't think there's really too much more to discuss.
1. Is a realtivity drive a real thing?
Yes, a realtivity drive is a theoretical concept proposed by Albert Einstein's theory of relativity. It is not yet a practical technology, but there is ongoing research and experimentation to make it a reality.
2. How does a realtivity drive work?
A realtivity drive works by manipulating the fabric of spacetime, allowing for faster-than-light travel. This is achieved by creating a "warp bubble" around the spacecraft, which contracts the space in front of it and expands the space behind it, effectively shrinking the distance it needs to travel.
3. Will a realtivity drive allow us to travel through time?
No, a realtivity drive does not allow for time travel. While it may appear that way to an outside observer, the travelers within the spacecraft experience time normally. The theory of relativity states that time can only move forward, and a realtivity drive does not change this fundamental principle.
4. Can a realtivity drive be used for interstellar travel?
Yes, the concept of a realtivity drive was proposed as a way to travel vast distances in space. It would allow for much faster travel compared to traditional rocket propulsion, making interstellar travel more feasible.
5. Are there any potential dangers or limitations of a realtivity drive?
There are several potential dangers and limitations associated with a realtivity drive. One major concern is the intense energy and radiation that would be generated during the creation of a warp bubble. There are also concerns about the potential effects on the fabric of spacetime and the possibility of causing unintended disruptions. Further research and testing are needed to address these concerns before a realtivity drive can become a reality.
