Homework Help: Rearrangement - Quickie easy
  1. Jan 21, 2010 #1
    Hello, I just need some quick help with the following, rearranging the below to make y the subject
    2. Relevant equations
    Rearrange x = (y^3+1)/(y^2+1) to find y
    3. The attempt at a solution
    Not sure , not been doing algebra for long
  3. Jan 21, 2010 #2
    tiny-tim
    Welcome to PF!
    Hi Toby_Obie! Welcome to PF! :smile:
    (try using the X2 tag just above the Reply box :wink:)
    Are you sure that's the question?
    I don't think there's any way of making y the subject, without knowing the solution to a general cubic equation. :redface:
  4. Jan 21, 2010 #3
    Question is correct - is it possible then ? There must be some way
  5. Jan 21, 2010 #4
    Re: Welcome to PF!
    You're over complicating a bit. It's probably just solving the equation in terms of y, which itself just means moving somethings to the other side of the equals side.
    Remember, what you do to one side of the equals sign, you do to the other side.
    hints:
    factor
    get rid of fractions,
    you'll have to move things around in both directions
    the answer has a fraction
  6. Jan 21, 2010 #5
    I'm searching for an answer in the following form :
    y = f(x)
    Can it be done
    It may be over complicating but I have to know
    Thanks for you help
  7. Jan 21, 2010 #6
    yes
    factor y^3+1, simplify, and you should be able to work it out from there. It's just a lot of shuffling from one side of the equation to the other. Keep stuff in factored form and factor some more.
  8. Jan 21, 2010 #7
    Sorry I don't get it
    Could someone help me out ?
  9. Jan 21, 2010 #8
    tiny-tim
    sorry, not me … i don't get it either :redface:
  10. Jan 21, 2010 #9
    I'm unsure how to release the x and y
    x = (y^3+1)/(y^2+1)
    x(y^2+1) = (y^3+1)
    (xy^2)+x = y^3+1
    x-1 = (y^3) - (xy^2) ?
    Factoring (y^3+1) only creates (y+1)(y^2-y+1)
  11. Jan 21, 2010 #10
    I've spent way too many pages on this, but basically I think you just have to keep rearranging the equations (adding, subtracting, multiplying, dividing, multiplying) until everything simplifies.
    Have you learned complex numbers yet? If so, you can use those to simplify things further.
  12. Jan 21, 2010 #11
    tiny-tim
    I repeat … I don't think there's any way of making y the subject, without knowing the solution to a general cubic equation.
  13. Jan 21, 2010 #12
    Sorry, I was slow on the uptake and totally missing your hint.
  14. Jan 22, 2010 #13
    HallsofIvy
    Hint? What hint? tiny-tim said exactly that in his first response and you said it was not true.
    From [itex]x= (y^3+ 1)/(y^2+ 1)[/itex] we have [itex]x(y^2+ 1)= xy^2+ x= y^3+ 1[/itex] so [itex]y^3- xy^2+ (1- x)= 0[/itex]. There no way to solve that for y, with general x, except by using the (very complicated!) cubic formula.
  15. Jan 22, 2010 #14
    Thanks guys
