Rearrangement Reaction
  1. Jan 15, 2007 #1
    phph
    ph-c-c-ch3 + H+ ->
    OH Br
    2. Relevant equations
    3. The attempt at a solution
    Here, the OH is protonated, and leaves as water. Then the phenolic group on the right carbon migrates to the left one leaving a +ive charge on the right carbon. What happens after that?
    If there was another OH group instead of Bromine, the hydrogen on the OH would leave, forming a c=O. What happens here?
    Im sorry if the presentation is unclear, but I dont know how to use latex for chem.
  3. Jan 15, 2007 #2
    Gokul43201
    Staff Emeritus
    Have you drawn the compound correctly? It isn't supposed to be...
    Code (Text):
    ph ph
     C-C-C-CH3
    HO Br
    is it?
  4. Jan 15, 2007 #3
    No. That didnt come out correctly. 1,1,2-triphenyl-1,2-propandiol, is the compound.
  5. Jan 15, 2007 #4
    GCT
    Use Chemdraw, it's free. Be sure to state the problem again, this time in a clearer form, mentioning all of the necessary information including those that were in the original post.
  6. Feb 1, 2007 #5
    chemisttree
    I'm assuming that you meant to write 1,1,2-triphenyl-2-bromo-1-propanol.
    You are correct that water will leave and generate a very stable benzylic cation which is further stabilized by the adjacent bromine. This will form a three membered ring, bromonium ion. The positive charge will reside on both the 1 and 2 carbons. This will probably not revert back to the vinyl compound through loss of Br+ (Br+ is a poor leaving group) even if Br- is present. What may happen is that the water might re-add to the bromonium ion system and regenerate the original bromohydrin. This will undoubtedly occur by the E1 mechanism and the fleeting, isolated charge (and thus the hydroxyl) will reside on the most stable carbonium ion... on the diphenyl-substituted carbon (the "1" position), regenerating starting material.
    You might consider that the H+ adds to the bromine (in the neutral compound) and then loses HBr leaving behind a stabilized cation alpha to a hydroxyl group. If this happens, the oxygen of the adjacent alcohol could migrate over to form an epoxide and regenerate a proton. What do we know about epoxides and strong acids? Strong acids add to epoxides in a Markovnikov fashion and the product would be 112-triphenyl-1-bromo-2-propanol, a new product. This is unlikely to happen however since the hydroxyl is much more basic (a likely target for H+) than bromine. Even if it did happen, the first reaction (adding H+ to OH group) would definitely occur and regenerate 1,1,2-tripheny-2-bromo-1-propanol.
    Therefore, if I had to provide the answer, I would submit the bromonium ion intermediate as the only reasonable answer.
